Old 06-10-2020, 04:01 PM #31
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by cashflow50 View Post
Question: just watched Timmys video one more time and came to the part where he stripped the bolt for the tensioner idler pulley. What’s the chances that happens? Have any of you had that issue?
Yes, it was stripped before I did the job by someone else. You'll be able to tell when you take the bolt out. If it comes out smoothly then it's good. If it's a fight to get every last thread out, it's been stripped. Do not overtighten it going back in, the reason why it's stripped is because the threads are in the oil pump not the block, and the oil pump is aluminum. If it does strip, use lock-tite on the threads and get it as snug as you can since you won't get the full torque spec. Then pray you'll never have to change it again!
Also it's totally up to you about the crank seal. I didn't want to mess with the crankshaft so I just left it alone. I also don't replace half-moons on the cylinder heads, rear main seals, blah blah blah. I know which seals are most likely to leak and I focus on those. I've seen more leaks from mis-aligned seals that someone tried to "fix" like the camshaft and crankshaft seals than I have from the original ones failing.
326WHP 347TQ
Old 06-10-2020, 07:16 PM #32
3bears 3bears is online now
Real Name: 3 Bears
Real Name: 3 Bears
kind of agree with this..I have been into engines with supposedly new seals...yep new...but not properly installed...wrong depth or twisted...sometimes...no touchy is best
3bears is online now   Reply With QuoteReply With Quote
Old 06-18-2020, 08:56 PM #33
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
I have everything so far except the crank bolt. I’ll get an oem one from the dealer. How much does a bolt cost at the stealership?
cashflow50 is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 01:23 AM #34
Ron Burgandy Ron Burgandy is offline
Ron Burgandy will become famous soon enough
$10-15
Sent from my iPhone using Tapatalk Pro
Ron Burgandy is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 08:48 PM #35
cashflow50's Avatar
cashflow50's Avatar
Do you guys put locktite on the crank, timing. Tensioner and the 2 pulley bolts?
Old 06-20-2020, 08:59 PM #36
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
The new crank bolt should have some type of locker on it. No on the rest......
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 09:37 PM #37
cashflow50's Avatar
cashflow50's Avatar
Dang thanks for the heads up. I was about to buy a bottle of blue.
Old 08-08-2020, 03:33 AM #38
cashflow50's Avatar
cashflow50's Avatar
After a long wait, I finally have some time to do the job and alone. Do I have to remove the neg battery cable?
Old 08-08-2020, 12:15 PM #39
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
It would be a very good idea to remove both cables.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 01:57 AM #40
cashflow50's Avatar
cashflow50's Avatar
Timing belt?
Done. Took me about 7 hrs. Not bad for one man noob. Thank you to all that helped
Old 08-12-2020, 08:35 AM #41
cashflow50's Avatar
cashflow50's Avatar
Originally Posted by shadow247 View Post
Get the Aisin kit on Amazon that includes all new pulleys, water pump and hydraulic tensioner. Watch Timmy's Videos to decide if you are comfortable doing the job. One tip I have is to make sure the foam seal on the plastic upper cover is good. If not, moisture will build up in there and on foggy mornings and cause horrible squealing, it's even worse when it's actually raining hard! Ask me how I know!
While you are there, it's a good idea to do the Valve cover gaskets/Intake Gaskets, Clean the throttle body, replace all the vacuum hoses you can touch, and do a solid inspection on the rest of them. You Valve covers are likley seeping already, use an inspection mirror to check between the firewall and block, this is where my leak started, now it's all the way around. I wish I had just paid my guy to do the VC gaskets 4 years ago when I did the new Timing Belt Kit.
My foam seal for the upper cover was kinda falling off. Just shoved it back in place. Where do you get them? Is there a part number?
Old 08-12-2020, 01:58 PM #42
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
11329-20010 This is the part number for a new gasket.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
belt , busy , doable , iphone , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
help pls - timing belt or timing chain? weifert Maintenance/Detailing 2 10-22-2012 07:12 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
