Old 06-09-2020, 02:37 AM #1
Crackership's Avatar
Crackership Crackership is offline
Real Name: Dave
Crackership is on a distinguished road
Real Name: Dave
Missfire Cyl#2
Hi all,
I recently purchased a 1996 Limited with 260k on the clock. I got it for a steal with a P0302 CEL for missfire cylinder #2. I've read every thread I can find that might help, but I've still got the missfire. I'm hoping someone can point me to something I've overlooked.
Here's what I've done so far:
- checked all the vacuum lines, some don't look great but no apparent leaks
- cleaned the MAF
- replaced the spark plugs (yes, got the correct 2-prong guys)
- replaced spark plugs wires
- replaced the coil for 5 and 2
- cleaned the throttle body and IAC
- Bench tested the IAC and it checks out
- replaced injectors
The only things left that I can think of are compression test and then check the timing. Any other ideas?
TIA!
Crackership is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 07:15 AM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Perform a compression or leak down test to get an idea of the physical health of the engine. The latter would be better.
Any coolant loss?
O2 sensors look original?
Check all the grounds as well.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 07:57 AM #3
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Any coolant loss?
Leak down test is needed, it's the gold standard on checking the engine for major issues.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 11:57 AM #4
Real Name: Dave
Real Name: Dave
Any coolant loss?
I'll do a compression test today.
No coolant loss at all.
The O2 sensors look original or, at least, very old. But I would think more of a general fueling issue would present with a bad O2, rather than a single cylinder miss. Is there something I'm missing there?
I've been checking every ground I find, is there a diagram of their locations that you're aware of?
Thanks!
Old 06-09-2020, 12:40 PM #5
spartacus's Avatar
spartacus's Avatar
Thanks!
Ground point diagram
Missfire Cyl#2-screenshot_2020-06-09-10-34-55-1-jpg
Old 06-09-2020, 01:20 PM #6
Real Name: Dave
Real Name: Dave
Thank you!
Old 06-09-2020, 01:34 PM #7
Thanks!
Usually that is the case with 02 sensors, though in a blue moon I have seen a lazy one cause such, though it is usually mated with a PO300.
Post up your numbers when finished. As @thegipper alluded to, a leak down test takes away all guesswork.
Old 06-09-2020, 02:02 PM #8
Real Name: Dave
Real Name: Dave
I'll do a compression test today. I don't have a leakdown tester, but I'll see if I can cobble something together with the hose form the compression tester. Is there a way to get the timing covers off enough to verify TDC without removing the upper radiator hose? I'm guessing not, but I can hope.
Old 06-09-2020, 02:32 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'm not sure if your year has it, but you may see if you have an igniter module. When I was dealing with my 4Runner misfire I diagnosed that module some to verify operation. Something to consider.
I'd also ohm out all your coil packs on the primary and secondary circuits.
Old 06-09-2020, 03:54 PM #10
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Is it noticeably running on 5 cylinders? Only at idle or accelerating/higher PRM's as well?
It takes a fair amount of compression leak to show up as a miss. SO much so that usually a 'shade' tree compression test can spot it.
Pull the wires on all three coils, then crank the motor around for a short bit. So you don't flood the motor with gas, just do it a few times round and round. And listen as the start labors over each compression. Whir, whir, whir, whir... LIsten for any spot int he cranking where it sort of sails on by a compression without slowing down (as much).
Easy, quick to do, no tools needed, and if you hear uneven cranking, then yes, you've got big problems and will need to do more diagnostic work. Leakdown tests are great because they tell you where the compression is going. Out the PCV system - bad piston/rings, maybe a HG. Out the cooling system, probably a bad HG. Out the intake or exhaust, something wrong with a valve.
JohnMc is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 04:40 PM #11
Real Name: Dave
Real Name: Dave
It is noticeably running rough. It's fairly smooth when cold, but gets progressively rougher as it warms up.
I pulled the plug quickly during lunch in preparation for a compression test this evening and noticed that the plug is black with fuel. So I did a quick spark test and have spark.. I'm not sure what to make of this..
Old 06-09-2020, 04:43 PM #12
Real Name: Dave
Real Name: Dave
Was this on a 3rd Gen 4Runner? I did a quick Google search and didn't find an igniter for the 3rd Gen, but maybe I'm just missing it?
Old 06-09-2020, 05:01 PM #13
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
What did the plug look like when you pulled it out ? If it looked different it can tell you alot. You can Start the engine remove radiator cap let the engine come up to temperature at idle when the engine is at operating temp look down the radiator neck see if there are any bubbles.
plcfcng is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 05:01 PM #14
Real Name: Patrick
Real Name: Patrick
Igniter Failure?
The dtc is P1300, but I didn't have any codes with a dead miss somehow so I did the diagnostics for P1300 as wells as everything for P0300. Ended up being one of my coil packs. The secondary side was about 100 ohms higher than the other 2 coil packs, but was still well within the specifications listed in the factory service manual.
Old 06-09-2020, 05:16 PM #15
Well then either it isn’t firing (ignition) or the injector is bad, even though you said you replaced them? OEM replacement?
Got a helper to crank over the engine as you test for spark?
cleaned , missfire , plugs , replaced , spark
Missfire cyl 5 and 2 Jackthewack 3rd gen T4Rs 36 12-30-2017 12:47 PM
96 4Runner missfire issue mmankins 3rd gen T4Rs 7 11-22-2013 06:36 AM
cylinder # 1 missfire gremlin curt4x4 3rd gen T4Rs 10 01-30-2013 12:57 PM
Missfire when cold alan_2011 3rd gen T4Rs 4 08-01-2011 11:34 PM
missfire fhornerguy 3rd gen T4Rs 5 08-19-2006 06:06 PM
