Originally Posted by phattyduck
The 01/02 fabric is a bit more delicate looking/feeling than the earlier stuff... I just took the whole thing off, got it wet, sprayed with simple green and scrubbed with a fingernail brush, rinse well, and let it dry. You can do a similar process with the seat belt if it is retracting slowly (just make sure it fully dries before you let it retract back into the reel).
You can't do that with much else on the interior since it doesn't come out so easily (then again, I did launder my front seat covers after removing them...).
Hey Charlie thanks for the tips on cleaning that armrest.
Took your advice, removed the cushion assembly and worked it with fingernail brush, warm water, Simple Green and Dawn dish soap.
Blotted it dry with clean white terry cloth towel and repeated 2X. Set it in the sun for couple hours for final dry.
Came out great, thanks again!
