Old 06-11-2020, 02:41 PM #16
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
[QUOTE=gamefreakgc;3502971]
Originally Posted by clearock View Post
Yes, one definitely can be added. But he's taking it to a shop and they won't have all those little bits on hand and will charge an arm and a leg or just flat out say they can't do it.
if the shop doesn't have the equipment i'm talking about i'd leave quickly as they r basic parts of a master fuel pressure set that any basic shop should have, every shop I've worked at has had 1, I have 2 diff brand name set i use 4 personal use. not trying to bust ur balls, just trying to get the point across that if a shop is charging u a lot just to check fuel pressure then they don't have a clue what they r doing and ur money is better spent else where... even if the shop didn't have the above it's not hard to make an adapter, which a good shop will not charge u 4 their learning curve.
clearock is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 10:38 PM #17
Former_Jeeper's Avatar
Former_Jeeper Former_Jeeper is offline
Real Name: Alex
Former_Jeeper is on a distinguished road
Real Name: Alex
Actually I know it’s a sin as far as forum members but since this is above my level of wrenching I’m taking it to be diagnosed at a dealership 🤯.......not to worry my friend that works there can give me a decent discount plus I figure they are more versed on Toyota specifically as well as oem and not cheap aftermarket parts.
So they should have all the necessary testing equip on hand.
Every man dies, not every man truly lives
Former_Jeeper is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 06:43 AM #18
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Originally Posted by thegipper View Post
When the head gasket started to go on my truck, my truck would shake for 15 seconds or so before it would smooth out. It also didn't blow any white smoke and only after a few weeks would the reservoir be down about a 1/2" or so. Never had any check engine lights for the shaking until it got really bad and I confirmed it was a blown head gasket.
I tried all of the quick "tests" for checking for a bad HG and all of them said I didn't have a blown head gasket until I did a leak down test. The second I pressurized cylinder #3 I had air bubbles coming out of my radiator.
I'm not saying for certain you have a blown HG but its a possibility. If you want to 100% rule it out or confirm it, do a leak down test.
AGREE thegipper... I think the HG should be looked into. Any white smoke out the tail pipe (step on the gas peddle and look)? Any white gunk in the filler cap? Bubbles in the radiator with cap removed when running at idle? Coolant level dropping a little every week?
Captsolo is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 09:40 AM #19
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
I agree that this sounds like a head gasket or injector problem. Here's how I would diagnose it:
Symptom: Misfire on startup. What's likely happening is that a cylinder is ingesting some fluid (Fuel or coolant) while the truck sits, and when you start it, it's washing out the spark, causing a misfire.
Test:
I'd start with a cold engine and pull each spark plug. Is one completely covered in fuel? Coolant?
Then I'd run a leakdown test with the radiator cap off. Look for bubbles in the radiator for each cylinder.
Good leakdown and no bubbles: Probably injector.
Bad leakdown and/or bubbles: Headgasket.
In my case I had a Cylinder 2 misfire on startup. I suspected a headgasket, but when I pulled the spark plugs, cylinder 2 was soaked in fuel. Leakdown was perfect, no bubbles.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 10:27 PM #20
Real Name: Alex
Real Name: Alex
Mystery solved.....
Official diagnoses is a Headgasket.
My friend that works at a dealership is going to have his master technician do BOTH head gasket s and timing belt/water pump also.
$2600 parts & labor
I thought of course about just doing the gasket that’s faulty as well as an engine swap but for several reasons decided against an engine swap as mine besides the gasket is in pristine well maintained shape good for another 200k easy.
I don’t want anymore problems as I have a 3 week old baby at home so I figured might as well get both gaskets done and hit the timing belt and water pump while they are at It and while it has the attention of a dealership Toyota master mechanic who knows what he is doing.
I was hoping for a vacuum leak or leaky fuel injector but wasn’t going to be so lucky.
I figured on a 22 year old engine with bolts that are 22 years old $2600 with my discount done with oem parts at a dealership with a master Toyota mechanic isn’t a terrible price considering $800 is in oem parts.
Change my mind
Thanks for the responses and ideas as always this forum is super helpful and knowledgeable
Old 06-25-2020, 12:07 AM #21
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Aww that's a real bummer. Head gaskets are starting to get more common as these engines age more and more. Not as bad as 2nd gens, that's for sure, but still becoming an issue. However, $2600 one sure does beat a car payment every month for the next 10 years. Besides, there's talk of another corona cash hand out from the gov't...
326WHP 347TQ
Old 06-25-2020, 02:18 AM #22
994wd 994wd is offline
994wd is on a distinguished road
Did it slowly get worse? I sometimes get a little bit of shaking ish from my motor when I idle it for a little while most of the time after driving a lot. I haven't done any of my plugs/wires/coils yet so I'm hoping it's just that. I also have a 99 with 160k currently.
994wd is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 05:51 AM #23
Real Name: Alex
Real Name: Alex
Yep it slowly got worse no codes, no noticeable coolant level change really either.
I did all the plugs wires iacv, pcv etc.......but in the end obviously it didn’t help bc it was coolant seeping in causing a rough idle.
I’m hesitant to spend this much money on it but I guess I’ll commit to keeping it going. Let’s just hope this isn’t the start of a money pit.
Hopefully your issue is something cheaper but ............sounds like a HG
Old 06-25-2020, 01:16 PM #24
I think too many people neglect their cooling systems, which leads to the head gaskets going bad from the coolant side in to the cylinder. (not counting the early 5vz gaskets/engines with the known issue) My mind could be changed with some other evidence though...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-25-2020, 05:54 PM #25
Gull81 Gull81 is offline
Gull81 is on a distinguished road
Which 5vz have a faulty gasket? I have a 1997 and a head gasket issue is the last thing I want in my life right now.
Gull81 is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 07:13 PM #26
'96's and maybe early 97's. Heck, it may have already been done on your truck if the recall applied.
Old 06-26-2020, 11:16 AM #27
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Any of the 5vz can have head gasket failure I have a 2001 that I replaced a head gasket I did one on a 98 and a 97. I think the head gasket will fail at some time at about 220,000 give or take 20,000 your mileage may vary. The only thing you can do keep the cooling system serviced when it does happen take care of it right a way it will only get worse. Don't wait you will end up overheating the engine causing more damage. The JDM engine is a way to go but that can be a crap shoot. If it's only a head gasket I would not go the JDM route but I would make sure I get the heads resurfaced and the valves cut.
plcfcng is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 07:01 PM #28
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
Totally agree with your statement as the motor ages a head gasket can happen and chances are it will happen. I had 1 blow on my 96 3rd gen at 300k and my son had 1 blow on his 4th 08 at 270k. Even the 4.7 v8 have them blow on their 4 runners or lexus when miles get up there. I've always maintained my motors and radiators but age and miles cause even Toyotas to break sometimes.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 02:15 AM #29
Majkmichael's Avatar
Majkmichael Majkmichael is offline
Majkmichael is on a distinguished road
Originally Posted by Former_Jeeper View Post
Ok so about a month ago the 4runner (99 3.4L Auto 150k) started shaking really bad but only at startup and only for about 10-15 seconds. So naturally as a somewhat mechanically inclined person I
Cleaned MAF sensor, replaced air filter, Replaced IACV valve, cleaned throttle body, replaced PCV valve, grommet, and hose. Replaced spark plugs with Proper OEM as well as NGK wires.
Shake did not go away as i thought it would. No codes have been thrown during this mystery also. Once the shaking stops it is smooth as butter for the remainder of the drive.
Fuel filter is relatively new. All 02 sensors are newish and proper Denso units.
I have used propane to search for vacuum leaks and did not find any, replaced some vacuum hoses as well (just to be anal).
Some of you have no doubt concluded maybe a headgasket. However, oil looks clean and radiator is full, no smoke or sweet smell out of the tailpipe.
So now I am stumped. Hopefully I missed something small that someone else can help me solve this mystery as I am about ready to take to a shop so they can charge me a ton of money only to replace stuff that doesnt need replaced and not fix the problem lol.
Thanks in advance.
Drive around for about 20 minutes then squeeze the upper radiator hose, if it feels like it pushes in at all you have a head gasket issue. I know you said you're not losing coolant but the tiniest little leak will cause it to run rough without showing a loss of coolant.
1999 Autumn Blaze Metallic Sr5 4x4 Bilstein 5100 Front/4th Gen Bilstein 5100 Rear OME 881/890 Sport Hood
2002 Sunfire Red Pearl Sr5 Sport 2wd
Majkmichael is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 07:10 AM #30
Every 4Runner I bought had a dead rad cap and wouldn’t let it build pressure.
However, saying that if you don’t have a overheating problem you could drive with the cap loose and see if it acts differently.
If lack of pressure makes it better you have a head gasket problem.
filter , mystery , proper , replaced , valve
Engine noise? 3RZ experts please help owyheerat 3rd gen T4Rs 10 12-12-2019 10:53 AM
Need the help of the experts here regarding a CEL... Jeff T 4th Gen T4Rs 9 08-03-2013 12:02 PM
Check Engine Light Mystery jabel1214 4th Gen T4Rs 9 01-17-2012 08:04 PM
Help from the experts Frankhenrylee 3rd gen T4Rs 7 08-31-2010 04:51 PM
