Old 06-10-2020, 07:11 PM #1
josh3rd josh3rd is offline
Real Name: Josh
josh3rd is on a distinguished road
Real Name: Josh
Name of part and other ?'s
fellas, 2000 v6 4 wheel drive Limited owner with 253k on her here. What is the name of the part that goes from the air box to the engine itself? And is it wise to get one off a 97 4R? Reason i'm asking is because right before where the mass air flow sensor is, the black tube is cracked at the top.
Also i am no mechanic by any means, but what little things can I repair/replace on my own and where to buy the parts at. A member suggested that I get a Torque ratchet which will be tomorrow. Oh yeah, should I get the 3/8" or 1/2"? Or both? They're kinda expensive but worth it i guess.
And I know there is always posts about the brake upgrade, so here's another one. I don't tow and if I did it would be something small so with that said, should I get the 199mm or 231mm?
Thanks in advance.
Josh
josh3rd is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 08:21 PM #2
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Thanks in advance.
Josh
Here are the parts between the airbox and the engine: TOYOTA 4RUNNERVZN185L-GKPZKA - TOOL-ENGINE-FUEL - AIR CLEANER | Japan Parts EU
Sounds like this is the part you need - 17881-62150 - HOSE, AIR CLEANER, NO.1 1788162150 Genuine Toyota HOSE, AIR CLEANER, NO.1 17881-62150 | eBay
The '97 system is different, you'd have to get the entire assembly, including the MAF. Most folks actually go the other way, convert the early '96-98 intakes to the newer 99+ system, because the MAF is easily replaceable and is much cheaper.
As for TBU, I'd stick with 199mm.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 08:48 PM #3
Real Name: Josh
Real Name: Josh
Awesome brother much appreciated
Old 06-10-2020, 09:52 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
If you don’t tow heavy loads and you don’t do a lot of crazy mountains forget the tundra upgrade. IMO anyway, the stock set up is fine for a stock 4Runner.
Most people go aftermarket parts for the upgrade but I’d keep the old oem hardware any day. Opinions will vary on this issue of course. I’d put oem pads/ shoes on if you need them and forget about it.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-10-2020, 09:59 PM #5
Real Name: Josh
Real Name: Josh
Kanoe, the man who had it before me kept meticulous mechanical or should I say maintenance records. And it seemed that he changed the pads and rotors every year. Now I don't think from what I seen in the records the mileage was astronomical. It was just normal 10 to 12 thousand miles. Not saying that you could not need a replacement or change because of the way they drove but he's old man and I'm assuming not hard at all. So I'm in or should I say I am under the belief that he had to change them because of the issue that they say the forerunners have. This is all assumption on my part
Old 06-10-2020, 11:02 PM #6
Kanoe's Avatar
Kanoe's Avatar
There is not an issue with the original oem brakes under normal driving circumstances (in my opinion). I'm all OEM and have had no issues in the 8 years, 100,000 km I have driven. Other than cleaning, lubing and flushing I have not touched the brakes at all. Mine is a 5spd so it is inherently easier on brakes than an auto.
I think a lot of brake issues arise once people start putting aftermarket parts on. If yours are already aftermarket then you might as well do as you like.
-2001 Echo D.D.
Old 06-11-2020, 12:57 AM #7
Real Name: Josh
Real Name: Josh
my girl is all factory brother
Old 06-11-2020, 08:07 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
5 speed vs auto is different on these front rotors. Mine keep warping no matter what I do on the automatic ones. I dont drive like Mario Andretti either. .;)
Perhaps it's the rolling hills around here. I just cant stand warping rotors though. So i be converting to 199mm Tumdra brakes upgrade to eliminate the issue. 3 to 6 months my rotors start warping.
I completely understand people wanting to keep them stock as that make sense I been going back and forth on this one for a while.
199mm , 3/8 , air , part , yeah
Toyota Online Part Diagrams and Part Numbers - Now Available to Public gamefreakgc 3rd gen T4Rs 17 01-14-2024 08:56 PM
Part number and source for fender flare part Kyngfish 3rd gen T4Rs 12 12-29-2023 05:25 PM
Can't find a part number on a bolt, dealer part guy was an idiot yota-runner 3rd gen T4Rs 8 02-02-2016 08:00 AM
Looking for a specific part part of the door lock...2002 4r moremeds17 3rd gen T4Rs 3 09-11-2013 12:31 PM
1998 4Runner Shifter Bushing and Seat Part (Canada). Can I use 2nd Gen Part? nobb 3rd gen T4Rs 6 02-03-2013 11:11 PM
