Old 06-15-2020, 06:42 PM #16
Originally Posted by ArmArak View Post
I was running 40 psi on the street and dropped down to 32 psi on the trail. Noted I will go down to around 20 next time. I guess I need a better compressor or maybe even a CO2 tank, because even airing back up from 32 to 40 took ages .
You should probably be running 30-35psi on the street - though that is dependent on tire and load.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-15-2020, 09:08 PM #17
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
On street, you should be running what your door jam says. If that seems to much run a chalk test. Fill tire to desired psi, paint a chalk stripe across tire, if chalk is left on outside edges lower psi, if center is untouched add psi. And also can tell you if your camber is messed up. Trail psi is by trial and error. It is silly to run over door jam psi on any tire on a 4runner on the street, unless your getting serious sidewall roll.
Just my .02 cents worth or the booz talking lol.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 09:29 PM #18
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Ya I thought 40 might have been too high, I guess I'll try out the chalk test that was suggested with some lower PSI. Ill try to progressively go down below 25 next time I hit a trail. I still have the stock wheels and I'm using Toyo M/T 255/85R16. What would you say is too low PSI? I don't want to have to try fitting a tire on the wheels when I'm on a trail.
Thanks
ArmArak is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 02:05 PM #19
Thanks
You are probably safe down to like 12psi, unless you are really bombing down dirt roads. 20psi is very safe (basically 0 chance of losing a bead). Most on here likely run under 20psi off road, the hardcore guys will be closer to 10psi.
front , lifted , rear , side , time
My First Time Off-Roading!! ArnavG544 5th gen T4Rs 21 08-26-2013 07:39 PM
First Time Off Roading(pics)! KurtL 3rd gen T4Rs 7 08-01-2012 02:03 PM
First time off-roading! Jester4kicks Off-Roading 8 07-29-2011 12:13 AM
First Time Off-roading mosha20 Gallery 11 01-19-2010 10:08 PM
First time Off Roading!! Richierollz 4th Gen T4Rs 5 11-10-2008 09:49 PM
