Old 06-14-2020, 11:04 PM #1
danwyl danwyl is offline
danwyl is on a distinguished road
199mm Caliper Wheel Fitment Issues
I recently just did the TBU upgrade with the 199mm calipers. Installation went smoothly but when putting on my wheels I discovered that there is some binding between the wheel and the caliper? I was under the assumption that the smaller caliper would not lead to any wheel fitment issues?
Can't seem to attach pictures, but here is the link to an imgur album showing the rubbing.
Wheel Rubbing - Album on Imgur
I see a couple options here:
1. Get a set of used wheels of craigslist that clear the calipers
2. Get a 1/4 inch spacer and perhaps longer threads?
3. Grind down the insides of my wheels to clear them.
What would be the best option?
danwyl is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 01:45 AM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Not number 3. Not a good option.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 09:18 AM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
#1 or 2 are viable options.
If you're dead set on these wheels, you could try grinding down a SMALL bit at a time of the caliper, until it clears. It looks like it's barely contacting.
Not a good practice overall, but it can be done if you can get by with removing a very small amount of material
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 09:20 PM #4
pdspen pdspen is offline
pdspen is on a distinguished road
I've been looking into doing this upgrade but haven't pulled the trigger yet because I was concerned about that rubbing potential. 1/4" spacers might not leave you enough contact on the hub for the hub-centric wheels. FWIW, you might be able to find some wheels that will clear on craigslist from someone who upgraded a newer 4runner. I picked up a set of 17" rims recently for $100. They aren't cosmetically perfect but they work.
‘99 SR5 Auto, V6, 4x4
pdspen is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 11:07 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I say either your pads are slighty too think or the rotors are as the 199mm upgrade mostly clears factory 3rd gen rims.
Heck even my 3rd gen rims clear on my 2009 tacoma truck and it has 17 inch rims on it.
Never grind or modify a rim as you knock it out of balance.
Your best bet is to take a 1/16 or 1/32 off your calipers were it contacts the rim..
Old 06-16-2020, 11:43 PM #6
I was suprised as well, I went OEM on the pads and rotors, and calipers are the cardone ones that others have used.
That's my worry with the 1/4 inch spacers, so it looks like I'll be picking up a set of new rims that clear the caliper.
Old 06-17-2020, 10:36 PM #7
Or you could just go with 1-1/4" proper spacers/adapters.
199mm , caliper , calipers , wheel , wheels
Tundra S13WE 199mm Caliper Hardware Part Numbers jhuerta22 3rd gen T4Rs 0 07-17-2015 04:22 PM
part numbers for S13WE 199mm caliper rebuild kit? hawkcharmer 3rd gen T4Rs 0 11-14-2014 09:33 PM
Tundra 199mm Caliper and Pads questions dms1 3rd gen T4Rs 10 04-29-2014 11:04 AM
199mm tundra brake caliper question hert1028 3rd gen T4Rs 20 03-13-2014 03:05 PM
16x7 Cragar Soft 8 wheels...199mm Tundra caliper fitment? boostincoupe2 3rd gen T4Rs 1 08-13-2013 10:30 PM
