Old 06-14-2020, 11:23 PM #1
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Limited Fender Flare Clips/Fasteners
Searched through a bunch of threads and essentially came up with the two part numbers of :
Limited Fender Flare / Cladding Removal and Re-Install
9090467036 - blue clips
9090467037 - red clips
it does appear that they aren't the actual factory clips or they superseded by Toyota at some point.
The above thread fails to mention the part numbers for the metal(?) rivets that go underneath the Limited Flares on the quarter panel and front fenders. Does anyone know the part numbers for them? Or is this just a rivet that is commonly found at a hardware store?
APhelps is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 04:26 PM #2
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
I just ordered some of the thick plastic clips that attach the liner inside the wheel well for the front fenders and the screws with washers that attach the fender flare and liner together. Could that be what you mean, the screw with washer for the fender flares?
Screw w/washer part# 90159-60476
Scratch that, while looking more I did see a rivet. Rivet part# 90269-04047
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 06:16 PM #3
If anyone is curious here are the dimensions for the rivet. 5/32" (4mm).
Toyota 5/32" (4mm) Specialty Rivets 90269-04047
Thanks for finding what I couldn't.
Old 06-16-2020, 01:26 PM #4
While the red and blue clips might fit (even though I think they are actually wrong), they don't just fit into the fender. I remember pulling out an insert in the rear fender flare but neither of these fit in the front slot.
I highly doubt that the fender flares mounting was change per model year as well (re-engineering is a very expensive thing).
Old 06-24-2020, 12:34 PM #5
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Did you drill those rivets out or are there other ways they can be removed?
For the flare that is attached to the rear door, did you remove the door panel to get to those red & blue clips?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 11:32 PM #6
You can break the rivet apart (its just thick plastic) or drill it.
For the rear door, don't know I'm not removing it. The rivets and clips aren't cheap and I'm looking to prep my 4runner for sale.
Old 06-25-2020, 09:57 AM #7
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The clips are different between early and late 3rd Gens.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 11:24 AM #8
well that thread was for a '97 while mine is a '98.
Anyways moving on. From a microfiche stand point most of the fasteners aren't easily found on camelback / etc. Contacting a dealer for part numbers is the way to go.
clips , limited , numbers , part , plastic
Removing Fender Flare Clips k3v11n 4th Gen T4Rs 14 02-03-2020 08:47 PM
Need Fender Flare internal clips Sotovo 3rd gen T4Rs 19 02-03-2020 08:46 PM
Limited rear fender flare clips? OldRigNewParts 3rd gen T4Rs 4 01-22-2018 09:26 PM
Limited Fender Flare Clips rossgoldie 3rd gen T4Rs 2 03-17-2017 10:45 PM
Limited fender flare clips and weatherstrip question yota_addict 3rd gen T4Rs 2 04-04-2016 05:30 PM
