Old 06-15-2020, 01:08 AM #1
bowrappyo's Avatar
bowrappyo bowrappyo is offline
bowrappyo is on a distinguished road
bowrappyo's Avatar
Rear tailgate issue help!
A friend pushed in the key hole in my rear tailgate. Has this happened to anybody? Any suggestions on a fix?
Here some photos; Imgur: The magic of the Internet
99 4Runner, Bow Hunter, Los Angeles
"The powerful play goes on, and you shall contribute a verse" - Whitman | @jrapp.yo
bowrappyo is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 03:47 PM #2
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
My guess is the clip that holds the cylinder in place broke or came loose. I think you might have to start stripping down the back panel.
As mentioned below, if I wasn't clear, gotta go from the inside of the back door.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 06:13 PM #3
The license plate surround can also break. You'll have to pull off the inner panels to diagnose.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-15-2020, 08:42 PM #4
AgeOfOctane AgeOfOctane is offline
AgeOfOctane is on a distinguished road
It happened on my '96. The lock is held in place with 2 screws that screw into a couple of plastic tubes. On mine, the 2 plastic tubes broke off. Once I got access to it (I can't remember what was involved in removing the license plate and handle assembly), I was able to put it back together using the same broken pieces, but with longer screws. My handle had started not working properly (too much play before it engaged), so I took the opportunity to bend a couple of little metal parts around to account for the worn plastic parts in the handle.
'96 SR5 - TBU, FJ Cruiser 8-hole wheels, OME 906 Rear Coils, Stock Struts, External Transmission Cooler, Center Console upgrade, 99+ Headlight upgrade, Rola Roof Rack with extension. Cargo storage/ sleeping platform.
AgeOfOctane is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 10:18 AM #5
drallan drallan is offline
drallan is on a distinguished road
Happened to me as well a few years ago. Finally got around to fixing it the other day. Was pretty simple. As others said the plastic screw tabs broke free. Once you remove the interior panels its pretty easy to see what happened. All I did was carefully apply some epoxy to where the screw tabs broke and held it in place for a few min. Just be careful not to get epoxy on any moving parts of the tumbler, but it was pretty obvious. Once it cured I then applied some JB Weld to the outside kind of like a caulk. I pressed it into the gap between licence plate housing and the lock Maryland (again don't get any on moving parts), there is a little rim of metal around the tumbler. It is probably more solid than ever before.
Only issue I ran into is that one of the wires broke when I was fiddling with it and now my window doesn't roll down with key. It still does with dash button. All the wires and plastic is super brittle on the 20+ year truck.
drallan is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 10:32 AM #6
Danger Mouse's Avatar
Danger Mouse Danger Mouse is offline
Danger Mouse is on a distinguished road
steel putty is also good for building up, or rebuilding around the area where the screws go. just make sure to leave a hole or original plastic for the screws. the putty hardens so it will crack if the screws arent going into the original plastic or a hole so just the threads bite.
Danger Mouse is offline   Reply With QuoteReply With Quote
fix , photos; , rear , suggestions , tailgate
Tailgate Window Issue: SOLVED Ser1clymb 3rd gen T4Rs 16 12-19-2019 03:49 PM
Swapped out decklid/tailgate onto '01 4Runner from a '97 - electrical issue? smallarmsdealer Problems & Warranty Issues 0 07-13-2018 03:55 PM
Key Whole Rear Tailgate Pushed Through? spoiler900 3rd gen T4Rs 2 05-21-2014 08:20 PM
Rear Tailgate Glass '94 T4R Dylan Classic T4Rs 13 04-07-2014 02:20 PM
Parts rig, Tailgate issue MT Tatman Classic T4Rs 3 05-01-2012 07:14 PM
