Originally Posted by Joelzy
Details? I've been chomping a the bit to get a plasma cutter but dont even know where to start.
I using a China freight titanium 45 a115 220 plasma cutter. It works very well and its price point is slightly under 1k.
I run it for a while at a time possible even 15 to 20 min straight. I have zero issues with it and will slice 1/8 at 15 amp on 120v.
Will go up to 5/8 plate on 240 45 amp. I just never deal with any steel that think.
Does require dry compressed air to blow the molten steel away.
I even melted away a lower control arm nut and my bushing wasnt smoking. This was on the 120 16 amp setting. Then I sliced the bolt off. Hit it with a 4 inch angle grinder and pushed the bolt right out that was seized
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
