Old 06-16-2020, 07:24 PM #1
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Brake Line Question (OEM vs Aftermarket)
Hi
I just lifted my 2001 and am interested in changing my brake lines as they are very worn. In the front I have a 3.5 inch lift and in the rear a 5 inch lift. Here is the thread for those interested: Tundra/LC Lift + First Time Off Roading
Do I need to get longer brake lines? Also should I get OEM or aftermarket ones and which would you guys recommend?
Thank you,
Armen
ArmArak is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 07:57 AM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
PERFORMANCE FRONT BRAKE LINE SET FOR 05+ TACOMA, 96+ 4RUNNER, 07+ FJ CRUISER, 99-06 TUNDRA (TF BLINE-06, RED OR BLACK)
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 09:24 AM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Originally Posted by ArmArak View Post
Hi
Thank you,
Armen
You only need extended line in the rear, the front line has a hard line that runs on the knuckle, so you don't have the issues with droop that you would on a jeep or other vehicle with a soft line running all the way down to the caliper.
The SS lines are a good upgrade for the front. I just picked up a set of Stoptechs from a member here. I'll be doing a writeup on that in the future.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 09:40 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Hi
Thank you,
Armen
With that much lift in the rear you will want to replace the rear brake lines (there are 2 lines in the rear for 2001-2002 4Runners) with extended brake lines. Wheeler's has a good quality set of braided stainless front and rear brake lines available. Most people go with braided stainless to replace the rubber brake lines to improve pedal feel. $60/axle
Fronts: PERFORMANCE FRONT BRAKE LINE SET FOR 05+ TACOMA, 96+ 4RUNNER, 07+ FJ CRUISER, 99-06 TUNDRA (TF BLINE-06, RED OR BLACK)
Rears: REAR BRAKE LINE SET FOR 2001-2002 4RUNNER WITH VSC (TF BLINE-12, RED OR BLACK)
Old 06-17-2020, 10:17 AM #5
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I'm running wheelers SS braided extended line in the rear ( 99s only have the 1) and it was easy to install and does the job. I don't think you'll really be able to tell differences between brands until much later down the road...you know durability and such.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:24 PM #6
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
I think I have some used SS lines for the front that I removed when I went to a LT setup if you're interested.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 09:00 PM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I will throw this out there....
1) yes you will need an extended line for the rear
2) the car is over 20 years old...so since you got to bleed the system replace the fronts at this time too.
brake lines can be tricky...meaning they can look good from the outside...but its a 20+ year old rubber...and I have seen them fail on the inside....well you could not "see" but bulge to the inside and restirct fluid flow...yes it can
so why not be done with it and do the fronts too ?
There has been many many threads about break issues on this forum...and again I will say...well 20 year old brake hose...hmmmmm
aftermarket , brake , inch , interested , lines
Extended brake line question BendRunner 4th Gen T4Rs 1 11-17-2018 03:57 PM
2001 SR5 brake line question pink_sleeve 3rd gen T4Rs 0 09-15-2017 06:42 AM
Brake line question vicar 3rd gen T4Rs 2 06-07-2014 05:57 AM
extended brake line question kolelt 3rd gen T4Rs 9 05-02-2014 05:29 PM
Brake Line Question rickashay 3rd gen T4Rs 0 10-04-2011 11:49 PM
