Old 06-23-2020, 08:37 AM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by pedalquickly View Post
I just thought of something. Will 02 struts and shocks work with 99 coils?
Yes it will
Old 06-23-2020, 08:43 AM #17
pedalquickly pedalquickly is offline
pedalquickly is on a distinguished road
Originally Posted by Bad Luck View Post
Yes it will
Thanks Bad Luck!! I really appreciate it!
pedalquickly is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 10:51 AM #18
I haven't began working on it yet and just securing all the parts I need. Are worn tire rod ends likely the culprit that makes this thing sensitive to wind on the interstate. I have limited funds at the moment and need to target the problem. If it is the the tie rods, should I replace both inner and outers?
Thanks
Old 06-25-2020, 01:04 PM #19
Thanks
At this age, almost anything in the steering system could be a problem - inner or outer tie rods, the rack itself, the rack guide, steering rack mounts, alignment, control arm bushings, even the steering shaft up in the cab.
You'll need to get under there and shake / pry things around and see what is loose.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
back , recommended , shocks , stock , suspension
Is suspension upgrade recommended for a CBI aluminum front bumper ? MrGainzz 5th gen T4Rs 2 04-14-2018 09:40 PM
Rebuilding front suspension - Recommended steps? JohnOfTheJungle 3rd gen T4Rs 11 05-15-2017 12:24 PM
Recommended Shop for Suspension Work (GTA, Canada) Batang.Gapo 5th gen T4Rs 0 11-11-2014 09:45 PM
Recommended Mechanic for Suspension Work sluggercz So Cal 1 07-02-2013 04:57 PM
Recommended Spare Parts to have while off-roading? JustSomeName Off-Roading 8 10-09-2012 04:27 PM
