Old 04-13-2021, 11:30 AM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
What is that bead of yellow grease in the front hub oil seal about?
What exactly is that bead of yellow grease for in the inner oil seal on the front hub? Nothing rides on it and it looks untouched since 1999 so doesn't seem to lubricate anything. It keeps dirt and moisture out? What kind of grease is it?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 02:02 AM #2
swapped_mini swapped_mini is offline
swapped_mini is on a distinguished road
Seals are generally greased so they install easily and without tearing, could be leftover from being greased at install? If it covers a small spring that runs around the seal, grease is often used to keep that little spring from popping out of the seal while it is tapped into place.
Those are my guesses.
swapped_mini is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 08:07 AM #3
Vansnxtweek's Avatar
Vansnxtweek Vansnxtweek is offline
Vansnxtweek will become famous soon enough
Hahahah that's kind of funny you ask..I was just wondering the same thing last week when I had everything apart.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
Vansnxtweek is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 01:34 PM #4
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
i think that's the right guess -- install with grease to avoid tearing and make it less of a fight. the FSM has that as a hint -- "Coat MP grease to the oil seal lip".
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
front , grease , hub , oil , seal
Sticking Brake, Heat, and Black Gunk/Grease in drum. Blown seal? OldManKamps 3rd gen T4Rs 4 01-05-2017 10:59 AM
Toyota TRD Tundra Bilstein Shocks Yellow/Yellow Yellow/Blue Springs Troybylt For Sale: T4R Items 2 10-20-2016 10:56 PM
Toyota yellow CV grease repo 3rd gen T4Rs 5 02-28-2016 03:24 PM
Yellow grease dawudih Maintenance/Detailing 2 07-21-2015 08:24 AM
WTB: Front Coils from Tundra TRD (yellow/yellow and yellow/blue) tbst For Sale: Suspension/Wheels/Tires 2 02-01-2012 12:29 AM
