Old 06-26-2020, 07:49 AM #31
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Originally Posted by anniesball72 View Post
Yes the manual ECM is 100% compatible with the auto harness. In my case I had to use a 2003-2004 Manual 4x4 ECM for my truck. Again there were no 2001-2002 manual ECM’s.
The function of the auto trans connector is no longer needed. You can take it apart or cut wires off the back and splice them at the cable end or up closer to the ECM if you want it to be more weather proof. They sell harness kits for modifying the wiring outside the ECM. That may be the cleanest....?
Yes just wire per that drawing. That’s what I used to figure it out.
Actually you need to jumper 6 to 9 and 7 to 3. You need to run 7 to 3 through the clutch release switch to have cruise.
I see, once again I was taking things to literal, it does make sense that I could just cut that plug off LOL
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 07:53 AM #32
Real Name: Werner
Real Name: Werner
Originally Posted by Team_Jake View Post
Your auto harness is compatible with your manual ECU.
If you only want to get your 4Runner driving, all you need to do is connect pins 5 & 6 together from your auto park/neutral connector.
The CORRECT way to do this is to run these wires to your clutch depress switch (plus wire the clutch release switch for cruise control, clutch start cancel switch, and reverse lights), but if you just want to start and run, all you need to do is cut these two wires before the park/neutral switch and connect them together, easy as that.
Note: these pin connector numbers are straight from my Toyota EWD book and do not match the diagram I posted earlier (I did not make that diagram, I copied it from another thread).
Because I am so short on time and I want to take my truck to the dunes for the first time on the 4th, im going to go this route possibly for now, and then when I get back and I can actually dig more into the EWD I can wire everything correctly. I just got my clutch cancel switch in the mail yesterday. I do want to do everything correctly and professionally so when im done its just the same as an oem swap. This is a lifesaver, you made it to where im 100% confident i can take this bad boy out for the 4th!
EDIT: Before my questions get annoying I have one more LOL. Can you direct me to where I can find this diagram in my EWD? Or should mine be the same (numerically speaking) as the pic you posted?
Old 06-26-2020, 07:54 AM #33
Real Name: Werner
Real Name: Werner
Originally Posted by RandyBobandy View Post
You can make it even easier if you just want to get it running for a test drive and take the neutral safety switch off of your automatic and plug it into the harness, then just turn the rotating piece all the way to one side like it would be if it was in park, that’s how I did it with mine before doing all the wiring
I didn’t use any specific pins because I had the pigtail connectors from all the switches and just spliced the wires into them
This is along the same lines as what Jake said, you both are lifesavers for this LOL.
Old 06-26-2020, 07:56 AM #34
Real Name: Werner
Real Name: Werner
Now i've just got to find this plug in my 2000 EWD to make sure that i know which two wires to connect. Unless all of these auto trans plugs have the same numbering assigned to each wiring and I can just use the pic Jake posted for reference
Old 06-26-2020, 07:58 AM #35
Real Name: Werner
Real Name: Werner
When I get this all figured out im going to have a manual harness for sale amongst a lot of other parts LOL
Old 06-26-2020, 08:03 AM #36
Real Name: Werner
Real Name: Werner
The other thing I realized is I didnt recieve the belhousing bolts for the manual when I purchased it. I thought they would be the same as the auto but it looks like I need a two that are longer than the rest? Any clue where I can source these locally? I was thinking of going to fastenall. I think these are a 1.25 or 1.5 pitch
Old 06-26-2020, 12:34 PM #37
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
It's the same.
Look at the EWD that @Bad Luck posted on the first page of this thread. The circuit you are interested in creating is on page 54 "Starting and Ignition (5VZ-FE)", you can compare how the A/T and the M/T function. For the A/T, the park/neutral position switch will complete the circuit between wires 5 and 6 when your A/T is in park or neutral which will allow you to start.
To see the which numbers correspond to which pins on the connectors, go to "Connectors List" starting on page 260. Scroll until you find connector P1 (on page 266) and you'll see it's the same as the image I posted earlier.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 03:22 PM #38
Real Name: Werner
Real Name: Werner
It's the same.
Oh heck yes, I appreciate this!!! I had found that diagram in the EWD before but did not synthesize the information prior to you explaining it, that helped me connect the dots! I did not however know how to find the connectors so thank you for that!!
Old 07-01-2020, 09:05 PM #39
Real Name: Werner
Real Name: Werner
Once again, I must say thank you to everyone on this thread! Turns out, you all were right of course LOL. Couldn't have gotten this swap done in time for the 4th without all of your help!!! Took it on a test drive today with everything officially swapped over and I tell you what, it was totally worth it! I will post somewhat of a writeup for others to find, however, I got so lucky that I didnt even need to swap over my wiring harness. 100% plug and play as I was told!!! Seems like I got lucky on this one!
Old 11-19-2020, 11:51 PM #40
nateboor nateboor is offline
nateboor is on a distinguished road
This thread is an awesome resource for me as I am doing the manual swap on my 2001! The hunt for the 03-04 ECU continues...
EDIT: WAIT. Verny! You live in Grand Rapids too???? Holy shit what are the chances. Lets link up sometime brother. I want to see your rig in person!
nateboor is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 01:35 AM #41
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
The vehicle I would import for certain from Japan would be an 80 Series Land Cruiser. In my mind they look very close to a 3rd gen 4runner and most of them out there are diesel.
Attachment 363874
At least when they look like this I think they resemble a larger 3rd gen.
Would love to get an FJ80. Guy in the town over from me has one that I pass by, to me they look like a Land Rover-4Runner mix. That fat 4.5L I6 sounds great too. Import would be smart, a 40th Anniversary Edition sold on BaT for $77k...
Old 04-23-2021, 05:56 AM #42
Real Name: Werner
Real Name: Werner
I havent been on here in a while so sorry for the late reply but I would be down for sure! I live right by New Holland Brewery off of Bridge St downtown!
Old 04-23-2021, 05:57 AM #43
Real Name: Werner
Real Name: Werner
My buddy has a 40th aniversary with the triple lock he bought it for 2500 bucks! Not a shabby deal but hes been beating the piss out of it unfortunately haha
Old 04-23-2021, 12:34 PM #44
Team_Jake's Avatar
Team_Jake's Avatar
For anyone reading this trying to figure out how to wire their 5-speed swap, I created a new thread a while back explaining all of this. Everything you need to know to properly wire your swap can be found here
---> 5-Speed Swap Wiring Diagram
harness , manual , needed , sr5 , swap
2000 SR5 Manual Trans Swap with MultiMode TCase VernySanders 3rd gen T4Rs 23 11-06-2022 10:01 PM
Complete 2000 4wd, manual, v6 swap into 2wd auto 1999 build/project deanx2009 3rd gen T4Rs 104 04-16-2020 01:53 PM
WTB 3rd gen 4runner 4x4 Auto/Manual 99-2000, SO-CAL pixologics For Sale: Vehicles 11 02-19-2020 07:45 PM
2000 T4R on Craiglist with manual AND auto transmission BE4Runner 3rd gen T4Rs 17 03-07-2016 10:59 PM
2000 4runner 4cyl. auto to manual transmision swap toritochis 3rd gen T4Rs 95 04-30-2012 01:31 PM
