Old 05-28-2005, 12:32 AM #1
Pranav's Avatar
Pranav Pranav is offline
Pranav is an unknown quantity at this point
Pranav's Avatar
Transmission pan bolts torque spec?
What is the torque spec for the drain pan bolt, and the numerous bolts holding the pan to the transmission case? Also, is there meant to be a crush washer on the drain bolt? When I started to change drain my ATF, I noticed that there was not a crush washer on the drain bolt (dealer was the last to change the ATF).
The drain bolt and most likely the threads on the pan have stripped, after I tightened the drain bolt by hand with a small 14mm box wrench. I'm not sure if is my fault or not as to why the bolt stripped (not sure if it was overtorqued previously by the dealer, or by myself), but it doesnt matter. We've removed the pan and hope to pick up a new pan+bolt at the dealer tommorrow.
IF it's possible, I may consider buying the right sized tap and see if rethreading the pan would actually work, if we cannot get a new pan in time.
Anyways to summarize, could anyone with an FSM help me out? :
1. Torque spec for drain pan mounting bolts
2. Torque spec for drain bolt
3. Drain bolt thread type/size (# X #.## mm)
4. Is there a drain pan bolt crush washer?
5. Which would you prefer? A metal gasket or the appliable sealant compound?
BTW it's for a '98 2WD V6...
Thanks in advance!
-Pranav (kicking himself right now after turning an easy ATF change into a 2-day ordeal)
'03 4runner V8 2WD
'98 4runner V6 2WD
'02 Accord LX 4cyl Sedan (mine!)
Pranav is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 12:43 AM #2
wdduck wdduck is offline
Real Name: Ken
wdduck is on a distinguished road
Real Name: Ken
Pan bolts are 65 inch lbs
Transmission filter bolts are 88 inch lbs
Yes, the drain plug does have a crush washer and the torque is 180 inch lbs
I am going to try the gasket this time instead of the silicone (just because the silicone is messy and I wanna do something different.)
I hope this helps
wdduck is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 08:14 AM #3
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I would get the rubber gasket they make for the transmission pan. Works great, no leaks.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
DIY: Non-Sealed Transmission Service for 4th Gen T4R's and Prior Mike the Wino Maintenance/Detailing 59 06-02-2021 11:35 AM
Flywheel bolts torque spec on 3.4? huhwhye 3rd gen T4Rs 2 12-18-2007 02:24 AM
Torque Converters...all you need to know Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-18-2002 05:10 PM
