Old 06-21-2020, 09:05 PM #1
Yisroel K Yisroel K is offline
Yisroel K is on a distinguished road
Help dont want to use mechanic
Hello, I bought a 1999 4runner about 2 years ago. The truck ran great until about 6 months ago I went to mechanic to fix breaks and rotors. The mechanic ended up switching out both axles, 4 breaks and rotors, and he told me he welded up my muffler. about 4 months ago the muffler sounded really bad but the truck was running fine so I left it. a month ago my check engine light came on with p0170. I went under the car to see it any hole on muffler (i though maybe check engine light from muffler) I saw the rear o2 sensor unplugged and hanging. I went to the store-bought a new gasket and put it back. the truck sounds great but engine light is still on. the truck is running really rich (100 miles per tank) I checked for vacuum leaks and cleaned the MAF but doesn't seem to help.
Please help.
Yisroel K is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 10:01 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Please help.
you need to clear the code. once the code is stored the check engine light will stay on. you can clear the code with one of these readers. hopefully there will be no new codes?
I have a cheap code reader and torque pro(app) on a cheap android tablet.
I think it was this one... then you need scanner software usually on your phone or tablet.
Amazon.com: Bafx Products - Wireless Bluetooth OBD2 / OBDII Diagnostic Car Scanner & Reader Tool for Android Devices - Read/Clear Your Check Engine Light & Much More: Automotive
Old 06-21-2020, 10:34 PM #3
Codes
Sorry I forgot to mention I did clear the code and it came back on.
Old 06-22-2020, 12:34 AM #4
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
This is not true.
The code will stay as long as the condition that caused the code to be present in the first place still continues.
Plenty of times, in my 4Runner and my VW, I had codes, replaced the necessary part, and the code was gone.
OP, it’s very possible that there is another condition to cause the code to be present.
Have you tried anything else? Looked for leaks, done any other kind of investigating?
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 12:37 AM #5
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
So if the mechanic had to weld your muffler, and then the rear O2 sensor nuts backed off (?), then what does the front O2 sensor look like?
I’m assuming your loud exhaust was due to the O2 sensor falling off?
Having trouble understanding this as generally exhaust bolts are rusted and hard to remove.
The front O2 sensor is the one most responsible for fuel mixture, not the rear one.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 01:09 AM #6
When I put the rear o2 sensor back on I had to use a whole bunch of washers because the bolts where somewhat striped.
Loud exhaust went away when I put o2 sensor back in its place, so I guess so.
The front o2 sensor is otherwise known as af sensor?
It was in its place should I take it out and clean it somehow?
Old 06-22-2020, 01:19 AM #7
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
If your sensor was just hanging it might be damaged. Try replacing it and then clear the code and see what happens. Mechanics are people too and they make all type of errors. If you really know your truck is running rich then chances are it is 1 of your 2 sensors.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 01:27 AM #8
Is there a way to clean the sensors?
Is there any tests to be done before just replacing the sensor and not know what it is?
Old 06-22-2020, 01:34 AM #9
You can use contact cleaning to clean them but if it was bouncing around underneath your truck it could be just damaged. I'm not sure you can test whether it is working or not.
Old 06-22-2020, 01:47 AM #10
Does the truck fall into a default mode if I unplug one of the sensors?
If so I can eliminate which sensor is the bad one.
Old 06-22-2020, 12:32 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Please help.
Your problem is likely the front oxygen sensor. The front oxygen sensor monitors fuel trim and the rear oxygen sensor monitors catalytic converter function.
Old 06-22-2020, 01:40 PM #12
Is there a way to tell without replacing it?
Don't want to spend money and not be the issue.
Old 06-22-2020, 01:46 PM #13
Please help.
The code is p0171 system too lean bank 1.
Freeze frame
Fuel system 1 status: cl
Calculated load value: 20.4%
Ect: 84c
Short term fuel trim bank 1: 19.5%
Long term fuel trim bank 1: 39.8%
Rpm: 695/min
Vehicle speed: 0mph
Should I do a vacuum exhaust test?
Old 06-22-2020, 01:47 PM #14
Real Name: Patrick
Real Name: Patrick
Besides checking every other thing that cause cause a fuel trim issue, not really.
Old 06-22-2020, 02:03 PM #15
I guess I'll have to switch it out.
My o2s11 is reading. 640 volts
My o2s12 is reading 0.000 volts and get it to 0.010-0.020volts on a 2500 rpm Rev.
Is that normal?
ago , engine , light , muffler , truck
Help I dont know what to use!!!!!!(PIC) JRisner Maintenance/Detailing 16 02-28-2022 10:23 PM
Are your sure u dont want these??? Thurlo76 Classic T4Rs 6 01-31-2021 06:27 PM
i dont know anything about this. Slapaho Classic T4Rs 12 11-24-2019 01:57 PM
I really dont get it... Whitson Metalworks 3rd gen T4Rs 15 06-10-2012 11:06 PM
I dont know what to do. Mitchc4216 3rd gen T4Rs 32 08-18-2008 11:53 PM
