Old 06-22-2020, 09:44 PM #1
CWccw CWccw is offline
CWccw is on a distinguished road
Biggest deep cycle that can fit
Currently using a group 29 deep cycle from my camper but when it comes time to upgrade since its not AGM, I want the biggest deep cycle I can fit. Would a H8 fit with supporting structure mods? Do those come AGM?
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 10:22 PM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Go check the classified section. Someone is selling a battery tray to fit a Group 31 battery. I haven't seen anyone put anything larger than a group 31, most other batteries are too tall.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 06:43 PM #3
bump
Old 06-24-2020, 07:26 AM #4
@ put an H8 battery in his rig a few years ago.
Old 06-25-2020, 02:15 AM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Assuming you are filling the stock battery location, a group 27 will be stock height but stick out another 2 inches towards the alternator. A g27 has almost as much capacity as a group 31. Make sure it has reversed terminals.
pluton is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 02:28 AM #6
994wd 994wd is offline
994wd is on a distinguished road
I have a 4s 180+ah lifepo4 battery I want to put in after I do my sound system with huge subwoofer and amp. Would be killer.
994wd is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 11:42 PM #7
pdspen pdspen is offline
pdspen is on a distinguished road
I put this one in recently because I already had it from my diesel Mercedes and it was only about a year old. I used self drilling screws to attach a beveled piece of 3/4 ply beneath it. The little rope is likely unnecessary but helps my paranoia.
Duracell part number 49(H8)
‘99 SR5 Auto, V6, 4x4
pdspen is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 12:43 AM #8
pauldub pauldub is offline
pauldub will become famous soon enough
I'm betting the one you have is an RV/Marine battery which really is not a deep cycle battery. Here are some deep cycle AGM batts: Motive AGM | Trojan Battery Company
pauldub is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 11:07 AM #9
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Ive got an H8 AGM. Its tight but it fits. H8 is the same size as group 31 but the posts are on the proper side.
It has to by a "hydrid" deep cycle/ starting" since it will be used to start the car everyday. A true deep cycle should not be used to start engines and will not have a cold cranking amps listed.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 11:17 AM #10
zacksc zacksc is offline
zacksc is on a distinguished road
deep cycle
I just ordered a Trojan Battery from Solar Biz. I think they have good deep cycle batteries.
zacksc is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 11:18 AM #11
agree
I has to by a "hydrid" deep cycle/ starting" since it will be used to start the car everyday. A true deep cycle should not be used to start engines and will not have a cold cranking amps listed.
Totally agree. Apples and oranges. A true deep cycle has thick plates and very little area and cannot cold crank. Most batteries sold as deep cycle are probably hybrids I would guess.
Old 06-27-2020, 11:28 AM #12
calimobber's Avatar
calimobber's Avatar
Im curious to see how the Trojan works for you, what one did you order? Ive looked at them for a long time. I have 2 Trojen 6v batteries(the T105's) on my trailer and they work awesome.
Old 06-30-2020, 08:15 PM #13
I just ordered a CBI group 31 battery tray so if a H8 fits, has the posts on the correct sides and is a starting/deep cycle battery then its an obvious choice.
Old 06-30-2020, 09:48 PM #14
I’m torn between a H8 or a 27F for my next battery.
agm , biggest , cycle , deep , fit
Single Deep Cycle install, another battery thread!! SirWilliamGoes 5th gen T4Rs 92 11-07-2020 09:23 AM
Extra deep cycle batteries SE4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 8 08-15-2016 09:23 PM
***northstar deep cycle battery group buy*** ramonortiz55 Group Buys 120 01-28-2016 05:53 PM
help w choosing a deep cycle battery Xrider237 General Discussions 10 06-13-2015 10:10 PM
Inverter, deep cycle battery questions. soj1057 Classic T4Rs 4 09-12-2013 10:48 PM
