Old 06-23-2020, 06:18 PM #1
raty4R's Avatar
raty4R raty4R is offline
raty4R is on a distinguished road
raty4R's Avatar
Replacing A/C temp control panel.
1999 4Runner SR5 manual control
Any one know of a write up or youtube video on replacing the temp/hvac control panel? I've searched for days. I find tons of replace the lights and a couple of replacing the unit but they always skip the part on disconnecting the cables on the back of the unit. I can't get mine out far enough to get to the cables behind. Anyone with a Chiltons or Haynes manual can you check and see if either gives detailed instructions. If one does I'll go buy one.
This is the part I'm talking about, my Temperature dial doesn't go to the blue cold area.
[IMG][/IMG]
raty4R is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 06:57 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I believe you can undo the cable to the coolant control flow valve located against the firewall under the hood and you should be good to go.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 08:00 PM #3
raty4R's Avatar
raty4R's Avatar
That cable(temp control) goes to the passenger footwell and then to the heater control valve on the firewall has enough slack.
There are two others on the drivers side of the panel, one goes to the 'air flow' selector and the other goes to the recirculate or outside air under the drivers side. I don't know how to get those out/off.
Old 06-23-2020, 11:19 PM #4
JJRunner JJRunner is offline
Real Name: J.J.
JJRunner is on a distinguished road
Real Name: J.J.
I think I know what you're talking about, but I can't quite recall what the problem/solution was...
Are you replacing with the same climate control module? Even though mine is a '97 (levers only), I swapped it with one from a '00 4Runner (levers, two knobs). The ebay seller that I bought from was selling the climate control with the cables luckily (they even color coded them haha), I noticed the 97' cables were different lengths with the 00' cables, and with a straight swap using original cables, I noticed the temperature knob wouldn't turn all the way...
With that said, I think there was a youtube video that showed how to swap out the A/C temp control but I can no longer find it. I think the user is Andy or @sleepydad but I may be wrong hehe, but I think you can ask them...
1997 4Runner Limited 4WD E-Locker // 245K
OME 880/906 | Bilstein 5100 | AIRAID M.I.T. | Yakima LoadWarrior | More to come...
JJRunner is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 09:44 AM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
[IMG][/IMG]
Yes that was me. you will need the cables from donor. it's been a while and I deleted that vid because it was only for the ebay sale @ the time.
I can't remember if the electric was also an issue?
Old 06-24-2020, 01:28 PM #6
raty4R's Avatar
raty4R's Avatar
Thanks @sleepydad , But how did you get the old unit out far enough from the dash to get to the cables?
Old 06-24-2020, 02:19 PM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you need to undo the cables from the other ends. leave them connected to the control unit. all of the cables should come out with the control unit.
it's been a while but I'm pretty sure that is how I ended up doing it.
Old 06-24-2020, 05:28 PM #8
raty4R's Avatar
raty4R's Avatar
Ha figured it out. Unit is replaced and working. It was a real bear to do. I was able to disconnect the cable and connectors from the unit. I'll update and add pictures when I get a chance in-case anyone else has to replace this style control.
cables , control , part , replacing , unit
Temp Control Switch??? sup3rdav1 Classic T4Rs 0 05-10-2013 04:23 PM
Driver TEMP bulb needs replacing - question rileyb76 4th Gen T4Rs 4 11-19-2010 10:38 AM
Temp control backlight 12guns 4th Gen T4Rs 1 03-06-2010 11:15 PM
Temp Control Panel Lighting polvadis 3rd gen T4Rs 11 05-24-2007 10:37 PM
Replacing Dash Panel Light Bulb SnowFly Classic T4Rs 2 11-06-2006 06:39 PM
