Originally Posted by Stereww
I agree, I assumed my original would work since nothing is really different. But the reason I am second guessing so much is because my fluid level was actually dropping when the tranny was hot. I filled to the cold line when it was off, and then when I ran it, the fluid level would drop a few inches. That isn't how I understand it should work.
There's your problem. You should be filling to the cold line again the engine on after the not running cold fill before allowing the transmission to warm up and run through the gears for a hot fluid level check. With the engine off the transmission pump isn't circulating fluid throughout the valve body, passages, etc which will give you a higher reading than with the engine running.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
