Old 06-25-2020, 04:32 PM #16
phattyduck phattyduck is online now
Originally Posted by Stereww View Post
I agree, I assumed my original would work since nothing is really different. But the reason I am second guessing so much is because my fluid level was actually dropping when the tranny was hot. I filled to the cold line when it was off, and then when I ran it, the fluid level would drop a few inches. That isn't how I understand it should work.
Are you checking it with the engine running in Park, after cycling through all gears on the shift lever?
Trans fluid will read WAY high if you do it when the engine is off.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 06-25-2020, 05:17 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
There's your problem. You should be filling to the cold line again the engine on after the not running cold fill before allowing the transmission to warm up and run through the gears for a hot fluid level check. With the engine off the transmission pump isn't circulating fluid throughout the valve body, passages, etc which will give you a higher reading than with the engine running.
dipstick , find , hilux , number , transmission
2004 4.7L V8 4x4 4Runner transmission swap Paxaran 4th Gen T4Rs 9 03-23-2019 10:14 AM
Real transmission filter - not the strainer in the pan Jhelms 3rd gen T4Rs 31 09-03-2017 09:59 AM
Real Time Help - transmission drain and fill snye 4th Gen T4Rs 8 04-17-2013 11:23 AM
2000 4Runner Transmission Swap lclements90 3rd gen T4Rs 1 09-16-2010 11:40 PM
I want to swap a manual transmission into my 93 4runner 4x4 osusae Classic T4Rs 3 10-13-2009 11:04 PM
