Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 10-02-2014, 07:40 AM #1
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
Chuckles' 98 Manual SR5 4Runner
General information:
1998 Toyota 4Runner SR5 4x4
3.4L 5VZ-FE V6
R150F 5-Speed Manual Transmission
Standard 2 Speed J-Shifter Transfer Case
4.10 Diff Gears
285,550+ Original Miles
Modification/ Repair List from 2013 and up
ENGINE
Original- Not Rebuilt
PCV Valve and Grommet
Silicone Vacuum Hoses
Toyota Oil Filter
Denso Spark Plug Wires
Valve Cover Gaskets
Tube Seals
Half Moons
Camshaft Seals
OEM Battery Tie-down
Battery Area Rust Removal + Paint
Denso Copper Spark Plugs
Throttle Body + Intake Plenum
Castrol GTX 10W-30 Motor Oil
Mitsuboshi Timing Belt
Aisin Water Pump
OEM Oil Cooler Line
Toyota Thermostat
Koyo/ NSK TB Rollers
Radiator Flush
Toyota/ Mitsuboshi Acc. Belts
PCV and Engine Breather Filters
OSC Tacoma #1985 Dual Core Radiator
Motorad Radiator Cap
Gates Radiator Hoses
Denso 80 amp alternator
INTAKE
Deckplate mod
High Engine Bay Snorkel
ISR Mod
MAF Sensor Cleaned
EXHAUST
Dynomax Super Turbo w/ stock 2.25" piping
Past- Thrush Welded, Walker Quietflow, and Straight Piped
DRIVETRAIN
Synthetic Valvoline 75W-90 Transfer Case
Valvoline Conventional 80-W90 in Front Diff, and Rear Diff
Redline MT-90 in Transmission
Transmission and Transfer Case Shifter Boots, Gaskets, and Grease
Rear Driveshaft Grease Zerk replaced
ADD 2 Low Mod- removed
Aisin Manual Locking Hubs
Manual Front Diff. Conversion (ADD Delete)
OEM Used Taco CV Axles
Aussie Locker in rear- removed
Cable Actuated Toyota E-Locker
Transmission/ T-Case Extended Free-Flow Breathers
Free-Flow Rear Diff Breather Extension to tail light
Aisin Clutch master and slave cylinders- 2016
Marlin Crawler clutch- 2016
OEM Toyota Front Wheel Bearings
National front axle seals
Timken rear wheel bearings
Doorman rear ABS rings
OEM Rear axle seals (inner and outer)
Doorman USA Made Lug Studs- rear
BRAKES
All Stock Sized
Red Front Calipers
Red OEM Drums
Toyota Pads- removed
Front Soft Lines- Napa
Driver’s Side Hard Line- Custom
Red parking brake cable
OEM Rotors
Wheeler's Rear SS Line
Wagner shoes
Doorman wheel cylinders
Akebono Pads- best pads I've ever used. I'm sold on them for life!
SUSPENSION
Duralast Front Sway Bar End Links
Toyota ’99 Tall Coils- rear removed
KYB Monomax Struts
KYB Front Spring Isolators
Rear sway bar removed
AirLift 1000 in Rear- removed
Front LBJs- and passenger again in 2016
LBJ Bolts
Tie Rod End Boots- Polyurethane
PolyTuff Rear Suspension Bushings
Prothane Sway Bar Bushings F&R
Energy Poly Steering Bushings
LC Tokico Rear Shocks (free blown ones lol)
Used OME 890 Rear Coils
WHEEL + TIRE
Street Tires: (set of 5)
4Runner 16” Split Spoke Wheels- Painted Black
BF Goodrich All Terrain T/A 235/85/16- lots of chunking
OEM Chrome Lug Nuts
Trail Tires: 235/85R16 Cooper STT Pro on 16" split 3 wheels painted gray
ARMOR
Stock gas tank and t-case Skid Plates haha
Doubled up gas tank skid coming soon
Lotus Rear LCA mount skids- red!
Savage Offroad Front Plates!
EXTERIOR LIGHTING
'99 Headlights- removed
Stock Tail Lights
Switchback LEDs Up Front
Depo Clear Front Turn Signals
LED Marker Lights
LED Flasher
Hi- Mount Stop Light- New Bulb + Cleaned + LED
Morimoto Mini H1 HID Projector Retrofits
LED Fog Lights
LED Brake Lights
LED Turn Signals
LED Reverse lights
LED 18W Pods in front x4
2x 18W Rear LED Pods
ELECTRICAL
OEM Towing Package
Red Horns
3 Gauge Ground Wire
Aftermarket Battery Terminals
OEM Fuse Box Cover
Driver’s Door Sensor Cutoff Switch
Fuel Pump Kill Switch
Seatbelt Sensor Delete
ABS Disable Switch
Airbag Disable Switch
CB Radio
Firestik Antenna
Ford Fiamm Horns- removed
Baofeng HAM Radio
Harbor Freight Air Horns- one of my favorite cheap mods- only $12 and they make me smile haha
EXTERIOR STYLING
SR5 Fender Flares- Removed
Rear Spoiler
Roof Rack
“Manual” Badge- removed
OEM Windshield Wiper Arms
Running Boards Removed
2nd Gen 4Runner Rear “4WD” Mud Flaps- removed
Reflectors on Hitch- removed
Plastidip Rear Emblems
Hitch Inversion
Red Tow Hooks
2nd Gen 4X4 Left Tow Hook
Debadged Rear Hatch
INTERIOR STYLING
Oak SR5 Cloth Front Buckets and Rear Bench- 120,000 miles as of April 2016
Driver’s Seat Bolt Repair
Oak Cargo Cover with Headrest Flaps Removed
4th Gen 4Runner Front Floormats
4Runner Embroidered Oak Cargo Mat
Clutch Pedal Helper Spring
8-Ball Shift Knob
Oak Leather Headrests
99+ Center Console with Cup Holders- Custom Rear Heater Cutout
OEM Clutch + Brake Pedal Covers
Seat Bracket Covers Removed
Driver’s Side Grab Handle
Ash Tray
Door Weather-stripping
Large Storage Compartment
Sound Deadening Throughout
Vinyl Floor
Plaid Center Console Lid
OEM Rear Floormats- Carpet
INTERIOR LIGHTING
LEDs
LED Cargo Lights
LED A/C Lights
Sylvania Incandescent Gauges
LED Hatch Lights
INTERIOR ELECTRICAL
Sunroof Switch Replaced
Sunroof Motor Replaced- junkyard used
New Ignition Cylinder
Dual Power Outlets in Front Passenger Area
A/C Switch
Clutch Start Cancel Button
VIP RS3000 Alarm
Remocon Remote
Relocated Antenna
Uniden 520 Pro XL CB- died
AnyTone Smart CB
SOUND SYSTEM
Stock Tweeters
Polk 6.5” with Tweeters Up Front
Kenwood 5.25 with Tweeters in the Back
Kenwood Excelon Single- DIN Head Unit
Stainless Steel Whip Antenna
Sound Ordinance 8" Sub
Been there, done that:
Tennessee:
Prentice Cooper
Bigfork
Coppinger Cove
Pickett State Forest
Hickory Flats
Cedars
Blackburn
CH
Windrock
Standing Stone
Catoosa
Nemo
Skinner Mountain
Alpine Mountain
Big Bottom
Kentucky:
LBL
Turkey Bay
Colorado:
coming soon
Wyoming:
coming soon
Montana:
coming soon
Idaho:
coming soon
Timeline: Chuckles' 98 Manual SR5 4Runner
Links throughout build thread. Updated 2-12-2018
AC Delco Rear Sway Bar End Links Chuckles' 98 Manual SR5 4Runner
Air Conditioning Idler Pulley Bearing Chuckles' 98 Manual SR5 4Runner
AISIN Hub Bolts Chuckles' 98 Manual SR5 4Runner
AISIN Hubs Chuckles' 98 Manual SR5 4Runner
Alternator Pule Repair Chuckles' 98 Manual SR5 4Runner
Alternator Rebuild Chuckles' 98 Manual SR5 4Runner
Aussie Locker Chuckles' 98 Manual SR5 4Runner
Awning- Chuckles' 98 Manual SR5 4Runner
Big 3 Chuckles' 98 Manual SR5 4Runner
BFG KOs and 99 Suspension Chuckles' 98 Manual SR5 4Runner
Bumper painting Chuckles' 98 Manual SR5 4Runner
Brake Shoes Chuckles' 98 Manual SR5 4Runner
Cabin vent filter Chuckles' 98 Manual SR5 4Runner
Camping Stove Chuckles' 98 Manual SR5 4Runner
Camping window vents Chuckles' 98 Manual SR5 4Runner
Cargo boxes Chuckles' 98 Manual SR5 4Runner
Cargo storage box enlarged Chuckles' 98 Manual SR5 4Runner
CB antenna Chuckles' 98 Manual SR5 4Runner
Clutch/ Rear main seal/ flywheel Chuckles' 98 Manual SR5 4Runner
Cooper STT Pro- 235/85R16 Chuckles' 98 Manual SR5 4Runner
Driveshaft Zerk Replacement Chuckles' 98 Manual SR5 4Runner
Dynomax Super Turbo Muffler Chuckles' 98 Manual SR5 4Runner
E-Locker Axle swap (includes rebuild of axles and brakes) Chuckles' 98 Manual SR5 4Runner
How To: Rear Wheel Bearings/ Seals at Home
E-Locker Cable Conversion Chuckles' 98 Manual SR5 4Runner
Fender rust fix Chuckles' 98 Manual SR5 4Runner
Field Monitor Unit Chuckles' 98 Manual SR5 4Runner
Firewall clearencing for tires Chuckles' 98 Manual SR5 4Runner
Front Bumper- Chuckles' 98 Manual SR5 4Runner
Front diff- ADD Delete Chuckles' 98 Manual SR5 4Runner
Front mud flaps Chuckles' 98 Manual SR5 4Runner
Hatch wiring fix
HID Morimoto Projector Retrofits Chuckles' 98 Manual SR5 4Runner
Hidden Snorkel Chuckles' 98 Manual SR5 4Runner
High clearance front bumper Chuckles' 98 Manual SR5 4Runner
High clearance windshield washer fluid tank Chuckles' 98 Manual SR5 4Runner
High flow air box Chuckles' 98 Manual SR5 4Runner
Hitch flip Chuckles' 98 Manual SR5 4Runner
ISR Chuckles' 98 Manual SR5 4Runner
K&N Filter Chuckles' 98 Manual SR5 4Runner
Land Cruiser rear shocks Chuckles' 98 Manual SR5 4Runner
LBJ Replacement Chuckles' 98 Manual SR5 4Runner
LED Pods Chuckles' 98 Manual SR5 4Runner
LED Revese lights Chuckles' 98 Manual SR5 4Runner
Lotus control arm mount skids Chuckles' 98 Manual SR5 4Runner
NOCO GB40 Chuckles' 98 Manual SR5 4Runner
Oil Cooler Seals Chuckles' 98 Manual SR5 4Runner
Oil pan gasket Chuckles' 98 Manual SR5 4Runner
Off-Road Low Lift Jack Chuckles' 98 Manual SR5 4Runner
PCV Filter Chuckles' 98 Manual SR5 4Runner
PCV Valve + Grommet Chuckles' 98 Manual SR5 4Runner
Plastidip Emblems Chuckles' 98 Manual SR5 4Runner
Polyurethane rear bushings Chuckles' 98 Manual SR5 4Runner
Rear Bump Stop Extension Chuckles' 98 Manual SR5 4Runner
Rear bumper Chuckles' 98 Manual SR5 4Runner
Rear diff breather Chuckles' 98 Manual SR5 4Runner
Redline MT-90 Chuckles' 98 Manual SR5 4Runner
Rock Lights Chuckles' 98 Manual SR5 4Runner
Roof Basket- Chuckles' 98 Manual SR5 4Runner
Rubber steering wheel upgrade/ downgrade Chuckles' 98 Manual SR5 4Runner
Savage Off-Road Skid Plates Chuckles' 98 Manual SR5 4Runner
Savage Off-Road Sliders Chuckles' 98 Manual SR5 4Runner
Seat swap Chuckles' 98 Manual SR5 4Runner
Shift Knob Chuckles' 98 Manual SR5 4Runner
Sleeping platform Chuckles' 98 Manual SR5 4Runner
Sound deadening- peel-n-seal Chuckles' 98 Manual SR5 4Runner
Steering Rack Replacement (AAE)- Chuckles' 98 Manual SR5 4Runner
Stereo upgrdes Chuckles' 98 Manual SR5 4Runner.
Sub- Chuckles' 98 Manual SR5 4Runner
Super Swampers Chuckles' 98 Manual SR5 4Runner
Switch panel Chuckles' 98 Manual SR5 4Runner
Switchback frint turn signals Chuckles' 98 Manual SR5 4Runner
Tacoma OSC 1985 Radiator Chuckles' 98 Manual SR5 4Runner
Tie Rod End Boots Chuckles' 98 Manual SR5 4Runner
Timing belt/ water pump Chuckles' 98 Manual SR5 4Runner
Thrush welded muffler Chuckles' 98 Manual SR5 4Runner
Tom Wood's Driveshaft Chuckles' 98 Manual SR5 4Runner
Transmission cleaning Chuckles' 98 Manual SR5 4Runner
Valve Cover Gaskets, PCV Valve, SPark Plugs, Half Moons, Tube Seals, Cam Plugs, etc. Chuckles' 98 Manual SR5 4Runner
Vinyl Flooring Chuckles' 98 Manual SR5 4Runner
Walker Quietflow Exhaust Chuckles' 98 Manual SR5 4Runner
Original Post:
After a search of almost two years of searching for a manual Toyota car or truck, I finally got one! It is a 1998 SR5 Manual truck with 240,000 miles. Bought it for $2900 last night and I sure am excited! The possible name is "Diamond in the Rough", but that probably won't stick. It needs a lot of work to make is safe. More details will come soon. I don't have any pictures at the moment except for the dealer ones:
Chuckles' 98 Manual SR5 4Runner-photo-5-jpg
Chuckles' 98 Manual SR5 4Runner-photo-jpg
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 10-02-2014, 07:58 AM #2
TNcaveman's Avatar
TNcaveman TNcaveman is offline
TNcaveman is on a distinguished road
TNcaveman's Avatar
That's my boy! I called her "a diamond in the rough" last night. Luckily, looks like mostly lots of little parts. Not one dent on the skids, almost no rust (two quarter sized spots where no one sees), and straight. This will be my 3rd 4Runner project. I sure miss "Old Blue" (what the guys at work call my old 4Runner).
Stephen hug from Chuckles
PS - long time no post
2018 4Runner - TR'aD Off Road - Old Man Emu shocks/springs. OPOR Slider
1989 4Runner (490,000 miles and sadly sold)
2004 4Runner (now at 285,000 mi. and sold)
2000 Celica GTS - the little bro with an attitude - speed limits toooooo loooow
TNcaveman is offline   Reply With QuoteReply With Quote
Old 10-02-2014, 02:10 PM #3
SR5Runner97 SR5Runner97 is offline
Real Name: Alec Thompson
SR5Runner97 is on a distinguished road
chuckles, i see you posting all the time in the classics section because of your dads runner. Glad to see you joined the 3rd gens. Goodluck with your runner. What kind of work is needed?
99 SR5 4Runner 3.4l
Factory elocker with 5 speed
265/70r17 terra grapplers
SR5Runner97 is offline   Reply With QuoteReply With Quote
Old 10-02-2014, 06:04 PM #4
68dave's Avatar
68dave 68dave is offline
68dave is on a distinguished road
68dave's Avatar
Good find! I wish my runner was a manual.
68dave is offline   Reply With QuoteReply With Quote
Old 10-02-2014, 06:16 PM #5
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Alright!! Can't wait to see the progression!
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 07:29 AM #6
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
Thanks guys! The most important work is sway bar end links (I did one last night), shocks and springs, valve cover gaskets, headlights, taillights, and a battery tie down. I have a more complete list and will post it when I get on my desktop computer- I will also post some pics. I also need to degrease the engine, front diff, and transmission to see where oil is leaking from.
Old 10-03-2014, 07:30 AM #7
TNcaveman's Avatar
TNcaveman's Avatar
Chuckles busted his first knuckle last night. He's now part of the club!
And he found out how hard it is to remove a single nut. I have never removed an 18 mm nut on Toyota until last night. I have a socket that size but no wrenches. I guess that will change soon. I'll let junior fill y'all in. But it is amazing what a sway bar end link does.
Stephen.
Old 10-03-2014, 08:14 AM #8
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Nice find Chuckles. I see the top doesn't come off, but I guess you can't have everything right?
I can't wait until my boy is old enough that we can start on his first truck.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 06:21 PM #9
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
I'm still in the process of making a list of things to do, so that will come in a little bit, but here are some pictures:
Chuckles' 98 Manual SR5 4Runner-dsc_3499-jpg
Chuckles' 98 Manual SR5 4Runner-dsc_3502-jpg
Chuckles' 98 Manual SR5 4Runner-dsc_3503-jpg
Bye, bye broken running boards!
Chuckles' 98 Manual SR5 4Runner-dsc_3522-jpg
Chuckles' 98 Manual SR5 4Runner-dsc_3523-jpg
Chuckles' 98 Manual SR5 4Runner-dsc_3521-jpg
Dirty engine runs great, just needs valve cover gaskets to stop the oil leak
Chuckles' 98 Manual SR5 4Runner-dsc_3525-jpg
Bad spot under the battery
Chuckles' 98 Manual SR5 4Runner-dsc_3526-jpg
Old 10-03-2014, 06:26 PM #10
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
Broken driver's seat... the front left bolt was ripped out of the floor, so we drilled through to the bottom and put a regular grade 8 bolt in. It needs replacing badly
Chuckles' 98 Manual SR5 4Runner-dsc_3520-jpg
Needs a center console- I want to find one out of a '99+ to have cup holders
Chuckles' 98 Manual SR5 4Runner-dsc_3514-jpg
Dirty back seats
Chuckles' 98 Manual SR5 4Runner-dsc_3510-jpg
Unused jack
Chuckles' 98 Manual SR5 4Runner-dsc_3511-jpg
Sway bar end links- broken one and a new one from autozone
Chuckles' 98 Manual SR5 4Runner-dsc_3528-jpg
Old 10-06-2014, 02:01 PM #11
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
I have a couple of questions:
Will 4 spoke 15" alloys from late 1st gens, 2nd gens, and t100s fit on the 3rd gens? Also, has anyone rigged up some rubber mud flaps that say "4WD" from a 1st Gen 4Runner or a 4wd pickup for the front and rears in place of the SR5 flares and running boards?
Old 10-06-2014, 02:23 PM #12
Moderator
Real Name: James
Moderator
Real Name: James
4 spokes will only fit if your truck came with 15" wheels from the factory (the door jamb sticker is a damn liar, check your wheels.)
The 15" models came with smaller front brake calipers. The 16" wheel models (standard only on Limited, both base and SR5 can have 15") came with larger calipers (S13WM casting) that will not suit a 15" rim.
It should be noted that all 3rd gen 4Runners can be upgraded to the Tundra brakes, 231 or 199mm. Of the two 3rd gen 4Runners I have, both have 231mm Tundra brakes (13WL casting). For this you should run at least a 16" rim, although the original 4Runner 6 spokes will not work for this.
Mudflaps can be done, it's all screws after all.
Old 10-06-2014, 02:29 PM #13
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
The 15" models came with smaller front brake calipers. The V6 model came with larger calipers (S13WM casting) that will not suit a 15" rim.
Thanks for the quick reply! That's a bummer about the wheels though because the tires for 16s are so expensive.
Old 10-13-2014, 10:07 AM #14
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
Been working on it all weekend…
Box of Parts!
Chuckles' 98 Manual SR5 4Runner-3-jpg
First was the battery tiedown. When I got it, it had a bungee cord and it broke, so I added some rope. Now it has a real one.
Chuckles' 98 Manual SR5 4Runner-1-jpg
Chuckles' 98 Manual SR5 4Runner-2-jpg
Pedal Covers
Chuckles' 98 Manual SR5 4Runner-4-jpg
Chuckles' 98 Manual SR5 4Runner-5-jpg
Chuckles' 98 Manual SR5 4Runner-6-jpg
Windshield wipers
Chuckles' 98 Manual SR5 4Runner-7-jpg
Sunroof switch worked for sliding forward, back, and tilt up. The tilt down didn't work, so we got one from the junkyard
Chuckles' 98 Manual SR5 4Runner-8-jpg
Old 10-13-2014, 10:09 AM #15
Chuckles89's Avatar
Real Name: Charlie
Chuckles89's Avatar
Real Name: Charlie
Also got a fuse box cover that can be read from the junkyard
Chuckles' 98 Manual SR5 4Runner-9-jpg
Then the cleaning started:
Before
Chuckles' 98 Manual SR5 4Runner-10-jpg
After
Chuckles' 98 Manual SR5 4Runner-11-jpg
Before
Chuckles' 98 Manual SR5 4Runner-12-jpg
After
Chuckles' 98 Manual SR5 4Runner-13-jpg
Cleaned the back seats and the seatbelt
Chuckles' 98 Manual SR5 4Runner-14-jpg
WTB - 98-00 4Runner 4x4 V6 Manual TurboIS_DJ Want to Buy/Trade 0 01-10-2014 07:44 PM
WTB: 3rd Gen 4runner 4x4, Manual(DFW) Strain Want to Buy/Trade 0 09-11-2013 12:29 AM
WTB: 3rd gen 4x4 4Runner, manual Erics4569 Want to Buy/Trade 1 09-09-2013 01:56 PM
WTB: 3rd gen 4x4 4Runner, manual Erics4569 Want to Buy/Trade 0 09-07-2013 03:45 PM
WTB: Manual 4Runner 4x4 bste3 Want to Buy/Trade 9 09-17-2009 08:18 PM
