Old 06-24-2020, 08:35 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by SeaFahrer View Post
You weren't kidding, just found some local Yota guys who say they are very familiar with the rear pinion on these going bad and can fix it for only $600. 9/10 fixes the whole problem, 1/10 you need a whole new diff. Bit worried because I'm not sure who long its been driven like this so could have warped the gears inside. But for $600 seems like a good deal to figure it out for me.
thinking I'll dirty my hands on the spark plugs and valve cover gaskets, but after watching some videos on replacing the rear diff that seemed a bit over my head currently
Will try and post some pics! Not sure how to yet XD
Chances are that mechanic who quoted you the first time doesn't even do the differential service. A lot of shops aren't equipped with the skills or tools. I asked around to have my limited-slip differential installed and they all said they contract out the differential rebuild. You were smart in asking around for a place that actually does the work, it's much cheaper that way.
That's a great idea to get your hands dirty and see how much you can do on your own, you'll save a ton of money that way. Plus if anything ever does go REALLY wrong, just have it towed to a shop and they will fix it. Just not that first shop you brought it to. If you can change the diff oil, change the spark plugs and wires, change the fluids (engine oil, transmission fluid and coolant) you'll be WAY ahead. Timing belt can be done but I'd ask for a mechanically inclined friend to help you because there are some things that can go wrong with that job if not done right. I agree with the other post about just ignoring it. If the belt ever does break, which is extremely rare by the way, you won't hurt a thing. It just won't drive lol.
326WHP 347TQ
Old 06-24-2020, 09:50 PM #17
SeaFahrer SeaFahrer is offline
SeaFahrer is on a distinguished road
Originally Posted by Chicago3rdgen View Post
its the wiring harness cover for the wires going to your MAF
Ah ok thank you! So it doesnt matter if its cracked right?
SeaFahrer is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 11:53 PM #18
Thats pretty huge to learn about the timing belt. It always seems like shops claim it needs to be done or you're screwed, but its like the most expensive regular repair.
I did take a look at the valve cover gaskets after they were mentioned and they were pretty coated in oil. So hoping that a quick clean and tighten will solve that but well see. Posting some of the leakage in the below link.
Imgur: The magic of the Internet
Yeah honestly I've been wanting to get onto the next level of repair after fluids, brakes and filters that I've done. I wasnt thinking it would be on this rig because we wanted it to be a bit more ready, but no time like the present! Also so much good help and encouragement here that I'm feeling pumped
Old 06-25-2020, 02:04 AM #19
994wd 994wd is offline
994wd is on a distinguished road
I'm late to the party but just seeing they want $500 for a valve cover gasket job that's highway robbery and the exact reason I do all my work myself. I'll be doing my VC gaskets soon as I get the parts and even if I did take it to a shop I'd never pay that much! The gasket kit for both VCs and all seals and everything you need to replace is less than $20.
994wd is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 09:24 AM #20
Yeah definitely not heading back to that shop. Going to call around and get some quotes on that fix as well in case my tightening of the bolts doesnt solve the leaking.
Old 06-25-2020, 01:12 PM #21
This feels like we are being trolled.
It is called split loom, because it comes like that. The split/crack is how you get the wires inside of it. That's exactly how it is supposed to look.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-25-2020, 01:45 PM #22
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric will become famous soon enough Bikeric will become famous soon enough
Bikeric's Avatar
Real Name: Eric
Honestly, that sounds like a lot of repairs for someone that is admittedly not mechanically inclined. Those fixes may be needed to get the 4Runner tip-top, but it is obviously still running now. How does the frame look? You should definitely confirm it is rust-free before the purchase. Minor surface rust is fine, but scale and/or holes would make me walk away.
Bikeric is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 02:26 PM #23
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
In some of the posts it sounds like the truck has been purchased, others, not. Weird.
258K - Y2K/E - Clock still works
Old 06-27-2020, 12:22 PM #24
ItsEvan23 ItsEvan23 is offline
ItsEvan23 is on a distinguished road
front sway bar stuff is super easy, napa sell both the brackets with bushings for $49, those bolts are 18lbs. Make sure you rotate tighetning them down, one then the other so the bracket sits perfect and doesnt brake again.
pretty simple job, and can replace endlinks bushings while you are in there, energy suspension has the good red urethane ones.
ItsEvan23 is offline   Reply With QuoteReply With Quote
210k , fixes , owner , pinion , put
gas mileage go-to fixes mendozer 3rd gen T4Rs 49 04-11-2016 03:55 PM
Alpha's 86 Fixes Alpha {MWB} Classic T4Rs 8 05-18-2012 08:16 AM
Sag fixes PiTTdAwG72 Classic T4Rs 5 02-17-2012 10:19 PM
Help, have a few fixes I need help with LakeTahoe94runner New Members 1 11-15-2011 02:53 PM
vibration fixes motion732 4th Gen T4Rs 0 03-06-2009 01:22 PM
