Old 06-29-2020, 01:45 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Majkmichael View Post
The organic additives in red antifreeze is not made to stop a huge leak. It is purely made to prolong the life of gaskets and seals in the cooling system. If you have a huge head gasket leak the coolant will not save you obviously. It is only supposed to fill microscopic leaks in these engines when they come out of the factory and as they age.
Interesting theory. Still doesn't explain how toyota motors with toyota red coolant are getting head gasket leaks.
Old 06-29-2020, 03:12 PM #17
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Toyota red is just a low/no silicates OAT coolant. It’s corrosion inhibitors last longer, but you still need to maintain your cooling system at least every 5 years or so.
Head gaskets die from corrosion, heat cycling, and being sandwiched between dissimilar metals.
That, and if you overheat your engine it’s really hard on them.
OAT coolants aren’t miracle potions. OEM’s just like them better in aluminum and plastic systems.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 10:49 AM #18
Majkmichael's Avatar
Majkmichael Majkmichael is offline
Majkmichael is on a distinguished road
Exactly, they do prolong the life of gaskets though
1999 Autumn Blaze Metallic Sr5 4x4 Bilstein 5100 Front/4th Gen Bilstein 5100 Rear OME 881/890 Sport Hood
2002 Sunfire Red Pearl Sr5 Sport 2wd
Majkmichael is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 11:21 AM #19
Like any coolant of any color it attempts to prolong the life of the engine components by attempting to keep corrosion at bay. It just does it in a different method than green coolant.
I’ve never heard of that “it plugs small holes” stuff you were saying.
Old 08-21-2020, 07:15 PM #20
Takeo77 Takeo77 is offline
Takeo77 is on a distinguished road
My opinion is that you downgraded. Jeeps break down far more.
Takeo77 is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 11:35 AM #21
Supermoney Supermoney is offline
Supermoney is on a distinguished road
A few months ago my CEL came on for a P0300(random cylinder misfire). Truck ran ok but it'd shake on startup so I thought it was probably fuel related or maybe a coil packs causing a misfire on both sides of the engine. I replaced the wires since they were original but not the plugs since I did them about 3k miles ago. I also replaced my PCV valve and it ran a little better but still CEL. I noticed I was ever so slowly losing coolant and my radiator hose was not holding pressure so I realized it was my head gasket. It was a very minor leak so I got some K Seal head gasket fix and poured it in the radiator and within a day my CEL was gone, truck ran great and radiator held pressure. This could have easily costed me hundreds if I threw parts at it.
Slightly old bump, but its most likely not your head gasket. Your heads have a crack in them. Usually near cylinder 3. Very common issue. Is it still holding up though?
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
Supermoney is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 05:03 PM #22
Good point, never heard of that problem. They're still holding up good though.
ago , cel , radiator , ran , replaced
P0300 GSPRunner 3rd gen T4Rs 9 04-04-2020 02:46 PM
P0300 P0306 Misfire fixed - fuel injector '99 4Runner Leebo 3rd gen T4Rs 41 07-14-2019 11:48 AM
P0300 P0302 P0305 my experience and finally fixed Kajo 3rd gen T4Rs 12 04-13-2016 04:01 PM
P0300, P0302, etc. sdb999 3rd gen T4Rs 4 03-06-2016 08:07 PM
Hard Breaking Transmission Downshifting kind of Hard RHINO-99 4th Gen T4Rs 1 05-18-2009 01:06 PM
