Old 06-30-2020, 02:34 AM #1
96TrailSurfer 96TrailSurfer is offline
96TrailSurfer is on a distinguished road
Steering Rack Guide
Hi Everyone,
I am on the path to eliminate at least substantially reduce the crazy steering wheel shake I am experiencing when driving over a rocky trail. Steering is rock solid on normal roads.
So far, I've narrowed it down to two culprits:
1. steering rack bushings - which are on the way
2. steering rack guide - which may or may not be bad, see below
My question for the gurus is two fold:
1. does this amount of play (about 1-1.5mm) indicate that the steering guide needs to be replaced?
Shared album - Seva Batkin - Google Photos
2. i've seen people replacing the original design steering guide (45504-35010) with a newer type (45504-35031).
If I do that, do I also need to replace the spring and cap?
96 Hilux Surf - 1KZ-TE (EGR delete, turbo boost controller, catch can), 2.5" lift in the front (Tundra Bilstein 5100s, Eibach 620#, and SPC UCAs), 3.5" lift in teh rear (Fox racing 2.5 remote resi adjustable 3rd gen Taco shocks and LC 8.5 wrap coils), 1" body lift (4crawler), ARB bumper, with SmittyBilt XRC 9.5k Gen 2 winch, 33" KO2s, D2S projector retrofits
96TrailSurfer is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 05:38 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Bushings do wear out but I don't think they're the cause of the rattle when roading over rough roads, its more likely the slip joint design Toyo put in for safety during a severe accident.
Read thru this for background, problem and solutions (hint: it involves a tack weld or two).
Diagnose and Fix Steering Play/Rattle | TTORA Forum
Old 06-30-2020, 09:17 AM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
If OP has a 96 he likely has no slip joint. It seems that was put in mid 97. My 96 has a solid skinny shaft rather than the fat 2 piece.
When I changed my guide it makes a lot of difference in tightening up movement at the drivers end of the steering rack. I changed all the pieces but I’m not sure all were needed. I’m sure you can reuse the spring and locknut but not sure about the cap. You’ll have to research or just try and see what happens. Maybe someone else will chime in.
About yours needing replacing, if you have the old design the new design is an improvement. It would be money well spent.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 09:26 AM #4
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Thumbs up
Originally Posted by 96TrailSurfer View Post
Hi Everyone,
How to: Replace steering rack guide- Pictures
Here you go bud. This thread has all the answers you seek. A fresh thread is always appreciated to push the topic to the top, since there are many people who may not know about this update.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 10:47 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Or, if you prefer videos, you can use these to fix your steering related issues.
Finally, if your steering rack is shot, you could use this video to replace it.
experiencing , guide , rack , replaced , steering
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Solid rack guide update in steering rack needs continual adjustment floatingkiwi 3rd gen T4Rs 13 03-20-2017 01:04 PM
Over tightened steering rack guide drallan 3rd gen T4Rs 0 10-16-2014 09:42 PM
New Style Steering Rack Guide Dous For Sale: T4R Items 5 05-01-2013 09:06 PM
