Old 07-02-2020, 01:35 AM #1
Ron Burgandy Ron Burgandy is offline
Ron Burgandy will become famous soon enough
Limited drivetrain into a sr5 manual?
Hi. I have a rotted out 99 5 speed that I paid $500 for that i'm going to rebuild, the axle housing has literally rusted through and needs to be replaced, among other things. I'm wondering how hard it would be if i were to buy the complete setup (rear axle, front diff, transfer case?) from a Limited with an elocker and 4.30 gears, and swap them into my 5 speed. The lower gearing would help with the 35's I plan on running, i'm also looking for 4.56 axles but quite a bit tougher to find. I know i'd have to wire the elocker, would the center diff feature work with this setup?
Ron Burgandy is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 07:13 AM #2
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
You'd need the 4WD computer from the kickpanel I believe, as well as the rear driveshaft. I believe the front is the same. @Tyler James Inc did the Multimode 5Spd swap I believe, might PM him, or perhaps he'll pop in.
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 11:37 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
As someone that suffers from intermittent AWD/4WD long engagement problems I wouldn't swap in a VF3 transfer case from a limited. When mine gives me enough problems I will be swapping in a normal j-shift VF2 transfer case and converting all the wiring to get rid of the 4wd computer. Just my $0.02
If you were to convert to the limited transfer case you would need a 4wd computer, electrical wiring diagram, rear driveshaft, and possibly front driveshaft. Some people have swapped and been able to re use the front drive shaft.
Old 07-08-2020, 12:50 PM #4
I also have a 99 limited that is my daily driver, the center lock is an absolute wonder in Minnesota during winter, it may introduce more things to go wrong but worth it IMO
Sent from my iPhone using Tapatalk Pro
diff , elocker , limited , swap , work
Limited VS. SR5 Drivetrain llessur2 5th gen T4Rs 8 12-16-2014 08:32 PM
Limited manual trans swap iamadam1122 3rd gen T4Rs 29 08-14-2014 10:57 PM
1990 3VZE Manual Drivetrain problems... bagelsjustbagels Classic T4Rs 9 08-02-2013 04:22 AM
2000 Limited 2WD to Manual/4WD Questions squeak12 3rd gen T4Rs 0 01-22-2012 09:22 PM
Runner 92 V6 Limited - Manual de Propietario pedro_arg Argentina 7 08-26-2006 05:11 AM
