Old 07-02-2020, 11:31 PM #1
AZZTR0CREEP's Avatar
AZZTR0CREEP AZZTR0CREEP is offline
AZZTR0CREEP is on a distinguished road
Bump then no power
i was on my way to harbor freight, pulled into the lot over the dip and lost all power. i can start the engine but then it seems like something is telling it to turn off. ill start it again and right away something is shutting it down. i gave it a kiss and it still happened. what now
‘97 4Runner Ltd rear locker 277k
‘08 GX470 (off-roading in it’s future)
‘ 02 GMC Sierra SLE “WORK TRUCK”
AZZTR0CREEP is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 12:46 AM #2
spartacus's Avatar
spartacus's Avatar
It's cranking and not turning over. I am guessing fuel pump if it's the original most likely cause. Throw some fuel starter in it and fire it up if it comes to life then it's the fuel pump.
Old 07-03-2020, 01:04 AM #3
it turns over and barely runs then turns off
Old 07-03-2020, 09:53 PM #4
bought a bluetooth scanner
i bought a bluetooth scanner and my error codes are;
p0100 mass air flow circuit
p0110 intake air temp circuit
p1300 inginter circuit malfuntion no.1
maybe these are easy fixes
Old 07-03-2020, 09:58 PM #5
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Check your MAF connection. If it comes loose it will do exactly as you are describing. Start then stall within a few seconds. It's the plug just upstream of the air box filter.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 01:14 AM #6
the 2 wire pigtail on the 2nd ignition coil had a broken clip. as soon as i secure the connection everything magically runs.
bump , power , start , telling , turn
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
All I did was go over a bump !!!! Drama1 5th gen T4Rs 5 03-22-2020 01:30 PM
Firewall bump? Offcamber 4th Gen T4Rs 10 12-21-2016 11:16 AM
&*#$(&(@!!! Bump Bump! 4Runner1371 4th Gen T4Rs 3 12-16-2007 03:26 PM
Bump? nauticalniremor Off Topic 2 08-12-2006 11:20 PM
