Originally Posted by 19963.4lsr5
It still acts like a bad tps.
Did you use aftermarket or OEM?
Does it do it holding a steady throttle?
Is your TV cable “aKa kick down” sticking and adjusted correctly?
Do you have a scanner that reads live data?
Aftermarket TPS. VEMO. That was two months ago though. And man... that was a PITA to replace even with the hood off.
Steady throttle seems to be okay, but it will randomly lock and unlock under acceleration.
I gave all the cables a visual inspection. There is some slack in them at idle, but I expect that.
What live data? I've got a both a bluetooth OBD2 dongle, and a Subaru/VAG cable. I don't have any Toyota specific software or app though. I've got the Torque Plus app that I generally use for pulling codes.
