Old 07-03-2020, 11:23 PM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Computer memory erased
1996 4 runner SR-5
I had no idea that when I replaced the battery, that I would erase the memory of the computer. In order to pass the smog test, the tech requires a fully functioning computer with a memory.
So, how much driving and of what type, does it take for the computer re-build a memory?
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 11:37 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Originally Posted by Traveler74 View Post
1996 4 runner SR-5
Don't overthink it. Just drive it like you normally would for a week and then take it back in. If it still doesn't show ready, give it another week. There isn't a magic procedure to follow. All of the emissions control systems need to go through cycles in order to show ready for a smog check, so one long drive doing some weird combination of speeds or rpm or something isn't going to do it. If you have an OBD reader, some of them have the ability to check for readiness for smog, so you can keep an eye on it yourself rather than needing to keep going back in to have them check it.
Skulking is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 12:59 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Be sure to mix in both freeway and city driving. It has to re-test the EVAP and catalyst systems by logging miles under certain speeds and timeframes.
326WHP 347TQ
Old 07-04-2020, 02:11 AM #4
dmppdx dmppdx is offline
dmppdx is on a distinguished road
There are also some things that will only reset at certain fuel tank levels so you may have to run the gas level down some before they will reset.
dmppdx is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 05:20 AM #5
The evap. If it’s anything like my Saturn the tank must be between 3/4 and 1/4 and above 45f outside.
Old 07-04-2020, 11:54 AM #6
My long drive to work (32 miles) will set the readiness monitors on my Saturn if it’s not winter time.
The same drive on my 4Runner will set them all, set all but the EVAP, set them all but the CAT.
This last round My EVAP wouldn’t set until it warmed up in late March or early April when I removed the battery and Alt to put install an oil pressure gauge.
Old 07-04-2020, 01:09 PM #7
Thank you all for the posts.
In my wildest dreams, I never would have imagined that the fuel tank level had anything to do with how a computer resets all of the functions. WOW ! Amazing.
Old 07-04-2020, 10:25 PM #8
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Here is chapter and verse from the horse's mouth as to how this works:
https://f01.justanswer.com/JACUSTOME...t-eg02-003.pdf
The On–Board Diagnostic (OBDII) system is designed to monitor the performance of
emission–related components and report any detected abnormalities in the form of
Diagnostic Trouble Codes (DTCs). Since the various components need to be monitored
during different driving conditions, the OBDII system is designed to run separate
monitoring programs called Readiness Monitors. Many state Inspection and
Maintenance (I/M) programs require that vehicles complete their Readiness Monitors
prior to beginning an emissions test.
The current status of the Readiness Monitors can be seen by using the Toyota Diagnostic
Tester with version 9.0 software (or newer), or a generic OBDII Scantool.
To view the Readiness Monitor status using the Toyota Diagnostic Tester, select “Monitor
Status” from the Enhanced OBDII Menu.
A status of “complete” indicates that the necessary conditions have been met to run the
performance tests for the related Readiness Monitor.
The Readiness Monitor will be reset to “incomplete” if:
ECU has lost power (battery or fuse).
DTCs have been cleared.
The conditions for running the Readiness Monitor have not been met.
In the event that any Readiness Monitor shows “incomplete,” follow the appropriate
Readiness Monitor Drive Pattern to change the readiness status to “complete.”
Refer to the Readiness Monitor Drive Pattern Application Table to determine which
drive pattern should be followed.
SECTION P
Get yourself a dang OBDII scantool. They all show readiness monitor status. Must have for even non-mechanics.
My Backyard Frame Swap
computer , driving , fully , functioning , memory
Seat Memory, can i have them!!!! IbrahimGTSR 4th Gen T4Rs 52 06-20-2018 01:16 PM
In Memory..... AsAkite Off Topic 5 04-30-2018 01:01 AM
memory seats bpearson 4th Gen T4Rs 5 06-21-2009 10:29 AM
Memory Seats hwheeler 4th Gen T4Rs 0 10-04-2007 11:28 PM
memory seats villahidalgo Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-04-2006 05:23 PM
