04-27-2018, 08:59 AM
Electrical gurus...Please check this out
I just bought a 99 Limited Monday. I bought it knowing there was a possibility it may need a transmission. He said second gear was gone. I got a smoking deal. Anyway, I drove it and noticed it shifted from 1-2 ok sometimes and would hesitate/slip on the 1-2 other times. He also said the gas gauge is erratic. I did some digging on here and noticed the gas gauge problem is a common issue among 99-00 4runners. Last night I drove it to a friends house a couple miles away. It shifted fine then started hunting/slipping again. It is throwing a P0758 code, which is a solenoid "B" Electrical. Not sure exactly what that means but I figure I will replace all three solenoids while I'm in there.
Here is the interesting part...I noticed that when the gas gauge is reading correctly, the transmission shifts and acts normal. When the gauge goes to "E" all of a sudden, that is when the transmission starts acting up. I'm gonna test this theory a couple of more times, but I'm pretty sure there is a pattern here. When I drove it back home, the gas gauge never dropped and the trans shifted normally all the way home.
Any insight here guys? Thanks.
1997 4Runner Limited: Elocker, OME 880/906/5100, 231 Tundra brakes, 265/75/16 Falken AT3W on Pro Comp 7069s
04-27-2018, 09:09 AM
Was this a flood vehicle?
04-27-2018, 09:32 AM
No. It is a pretty clean one. He's owned it for the last 5 years or so. He said Saturday morning is when the transmission went south on him. Not sure when the gas gauge started freaking out. Timing belt was done at 232k, sitting at 262k now. Fluids all look good. It appears he spent some time and money to keep it maintained.
04-27-2018, 10:23 AM
You can try disconnecting the shift solenoid connectors at the tranny (outside of the tranny, not the connections on the inside) and try manually shifting through the gears.
This is a test procedure in the FSM to isolate if the shifting problems are related to the solenoids or not. By manually shifting through the gears and having the solenoids disconnected, you will know for sure if its the solenoids. If it shifts fine when done manually, you at least know that the transmission is physically ok.
I also believe one of the last possible causes of erratic shifting according to the FSM, is the ECM itself. That could possibly explain your funky electrical problems but I'm not sure how the fuel level gauge works and if it involves the ECM or not.
If it shifts fine manually, you can drop the pan and pull the shift solenoids and bench test them. There are procedures in the FSM for doing it (ohm check, 12v power test and a pressure test).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
04-27-2018, 10:35 AM
Also try using the ECT button and select power, if you notice a change then the problem is more likely a dirty filter/oil. This was the case in my Tacoma. Are you getting a flashing "overdrive off" light?
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
04-27-2018, 11:49 AM
'it wouldn't hurt to make sure your grounds are good. bad grounds cause weird issues.
Reason: more info
04-27-2018, 12:05 PM
It shifts fine auto or manually as long as the gas gauge is not spazzing out. Thanks for the input
04-27-2018, 12:08 PM
I usually keep ect on but I'll check to see if I notice a difference. No flashing od light. The fluid is clean as can be. I'll know more about the filter when I drop the pan.
04-27-2018, 12:09 PM
Which grounds do I check other than the gaggle by the intake?
04-27-2018, 12:57 PM
As many as you can find.
04-27-2018, 01:02 PM
Originally Posted by 68chargerjmp
which grounds do i check other than the gaggle by the intake?
04-27-2018, 01:04 PM
04-27-2018, 01:59 PM
Real Name: C8H18 Mike
The intermittency sounds like you might have a short in your wire harness somewhere.
I would visually inspect all wiring under the vehicle and engine/transmission looking for worn insulation, possibly even animal/rodent damage.
Luck
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
04-27-2018, 02:05 PM
rear grounds
04-27-2018, 02:51 PM
Another possibility that I have been experiencing (and have the parts to fix, as of yesterday) - a problem with the circuit board on the back of the gauge cluster.
My errors have been P1780 and at separate times the left turn signal would activate the reverse lights...
I say this because, like grounds, the gauge cluster is about the only place the gas gauge circuit and the transmission control circuitry comes near each other.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
