Old 07-05-2020, 10:43 PM #1
jrkiernan's Avatar
jrkiernan jrkiernan is offline
Real Name: Josh
jrkiernan will become famous soon enough
jrkiernan's Avatar
Real Name: Josh
2wd auto vibration above 55mph.
I have a 2wd 2001 T4R auto and have been experiencing a vibration above 55 mph under acceleration. Once I let off the gas it mostly goes away. Fluids are good and not sure what to look into next.
jrkiernan is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:43 AM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Check the u joints
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 08:18 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+ 1 on the u joints.
Old 07-06-2020, 01:48 PM #4
Not just u-joints. There is a good chance the whole rear driveshaft needs replacement. The 2WD prop shaft has a rubber vibration dampener/coupler that wears out and requires a complete shaft replacement to fix.
It *could* just be u-joints, but be prepared for it to be the whole shaft.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-06-2020, 01:52 PM #5
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
X3 ujoints. You also state 2wd and your avatar appears lifted...if so depending on how much lift you've done your slip yoke may not fully seated on the output shaft causing it to vibrate and wobble at higher speeds when the drive shaft is rotating faster. If u joints are good then measure drive line angles make sure they match. Then disconnect your drive shaft and slide it all the way in till it bottoms out and measure the space between the diff and drive shaft...if you got an inch or more of space you may need a drive shaft spacer. For what it's worth if you have an inch of space when the slip yoke is bottomed out don't get a 1 inch spacer...you dont want your yoke bottomed out. If it's an inch gap maybe 3/4 spacer so your skip yoke still has some movement. You're just trying to get the slip seated well again.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 11:23 PM #6
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
You can some times get vibration just from road conditions. To rule this out what I did was jack the rear wheels up with the 4runner pointed in a safe direction place jack stands under the rear wheels and chock the front wheels. Slowly throttle the engine up to the offending speed allowing the transmission to shift. As you try different things for me this was a time saver. I had a rebuilt drive shaft that had u-joints that were the wrong size if you replace them only use Spicer or Toyota I don't have the part number at hand. What I found out was the cross was to small allowing the drive line to move when up and down not in the normal failure of bad caps. Even after replacing the Drive line it was still out of balance so I was able to balance it using a hose clamp method (very old school but I am up to 20,000 mile things are still great)
plcfcng is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 01:32 AM #7
jrkiernan's Avatar
Real Name: Josh
jrkiernan's Avatar
Real Name: Josh
Thumbs up
Thanks for all the info.
I had some time to look at it and 1 of the U joint caps were destroyed. Im not sure if the entire shift is bad as it did not look cracked. This is my mom's car and I asked how long it has been doing this her answer was not sure but I can hear it over my radio so its annoying now. Hahaha....
The T4r in my pic is my 2000 4wd.
Thanks again for the info.
Old 07-09-2020, 01:58 AM #8
davidch davidch is offline
davidch will become famous soon enough
In January I installed a driveshaft from this firm
Toyota Replacement Driveshafts
into a 2WD Gen3 4Runner, automatic transmission, 4-cylinder engine (can't recall its year).
The results were good; my friend's son was pleased. If this drive shaft's bearing wear out, they're standard Spicer bearings which are widely available.
davidch is offline   Reply With QuoteReply With Quote
2wd , auto , fluids , good , vibration
Mystery noise when off gas above 55mph in 4wd Dane Hauler Problems & Warranty Issues 4 02-10-2017 05:10 PM
Top Speed only 55mph sdot2010 Classic T4Rs 15 07-01-2015 06:38 PM
2000 4Runner- Auto-lock & Auto-unlock ToyGuy1023 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-03-2013 01:00 PM
Eastman's Auto [Barre, VT] & Cape Cod Auto Connection [Hyannis, MA] PrelateBishop General Discussions 3 08-20-2010 08:18 PM
