Old 07-06-2020, 12:17 AM #1
steveh steveh is offline
steveh is on a distinguished road
Towing Behind Motorhome
So, what could go wrong flat towing my '99 4Runner behind a motorhome? I mean, beyond towing a ... jeep.
steveh is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:04 AM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Burn up the output bearings on the transfer case I believe.
Far as I know these have to be trailer towed, dolly with rear driveline removed, or flat tow with both drive lines removed.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:13 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Read the owner's manual on this subject.
I have seen prop shaft disconnect devices installed on the 3rd gen, but don't have any user experiences to report.
pluton is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:13 AM #4
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
I always tow my 4 runner on my Carson utility trailer behind my motorhome. It saves wear and tear on the 4 runner and the trailer just needs occasional tires and wheel bearing greased. If you need a tow truck to tow you these things require a flat bed and can't be towed by a uhaul dolly either.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:53 PM #5
This is the answer right here. Can also ruin the transmission if left in 2WD with the driveshaft still connected.
With the rear driveshaft disconnected (manual or with some device), it can be flat-towed in 2WD.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-06-2021, 10:40 PM #6
Does this mean it can be flat towed with a manual transmission?
Old 02-07-2021, 03:27 PM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
with driveshaft disconnected
Old 02-08-2021, 12:47 AM #8
What breaks if you don't disconnect the driveshaft? Specifically? The book says tow dolly with xfer in 2wd and xmission in neutral. So what's the difference? Any actual personal experience with it? I have a Sprinter based RV and adding a trailer overloads it. A tow dolly is my current option. I know the old FJ4x had steering geometry problems with flat towing, but I would think Toyota would have been able to fix those problems with the IFS. I flat towed my '85 4Runner 900 miles one day with no problem. I can see the problem with an automatic, but I don't see it with a manual xmission. I also just updated my '99 4Runner with a '21 Taco 6 speed, and thinking tow dolly anyway with that as well. The book for the '21 says not to flat tow is all - "not designed for it."
Old 02-08-2021, 10:25 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What book are you referring to? The owner's manual for your 4Runner?
Old 02-08-2021, 12:22 PM #10
HiLife HiLife is offline
Doesn't the transfer case have a oil pump in it?
I would think the reason why for removing the rear driveshaft while being towed is to prevent the rear output bearing (among other things) in the transfer case from turning without oil.
Old 02-08-2021, 01:43 PM #11
Yes, the issue is the transfer case oil pump, which is on the *input* side of the transfer case. If the transfer case is in neutral, it isn't lubricating the transfer case (=boom)
Same deal with the manual transmission and neutral. The oiling doesn't work correctly with only the output shaft spinning.
Old 02-08-2021, 01:47 PM #12
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
i dollied mine from texas and just disconnected the rear driveshaft. Takes a couple minutes and better safe than sorry. Considered flat tow because of weight as i was towing with a frontier but read a thread similar to this one and didnt seem worth the test.
One thing i did run into was that the standard uhaul tires straps didnt quite fit over 33s so i had to unload and go buy a set from Northern Tool before leaving.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 02:46 PM #13
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
For anyone who wants pictures of how bad flat towing can go, check out this article.
Skulking is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 03:34 PM #14
Real Name: Patrick
Real Name: Patrick
I saw the video on a facebook mechanic's page and it's impressive
Old 03-17-2021, 11:44 PM #15
All kinds of bad.
4runner , flat , motorhome , towing , wrong
Towing 4Runner with Motorhome Nunyabiz 3rd gen T4Rs 0 07-07-2014 06:54 PM
Flat Towing 92 4Runner Behind Motorhome jefeblanco Classic T4Rs 1 08-23-2010 09:58 PM
Towing a 24-27' Boat with the V8 - What are you towing? rmd0311 4th Gen T4Rs 7 09-10-2009 08:36 PM
Your Friday laugh: Top Gear's Great Motorhome race. Ruffian Off Topic 10 07-30-2009 07:33 PM
towing HAUNT14 4th Gen T4Rs 3 06-25-2007 06:44 PM
