Old 07-06-2020, 05:15 PM #1
earth1 earth1 is offline
earth1 is on a distinguished road
96-99 tailgate relay module pinout
I can't find a schematic. Trying to chase loss of power to the module.
I could use some help to find out why my console switch doesn't work. I replaced a bad motor and in the process may have shorted something. I ID'ed some pins: key on, up/down (I think), battery constant, ground (perhaps). After changing the motor I only get power at the KEY ON pin. Fuses are good and the 2 grounds I can find look normal.
I am a wiring idiot, and have hit my ceiling.
87/99 frankenshit 4Runner hybrid (1st gen body on a 3rd gen)
66 FJ45 workrod
13 4Runner Limited
earth1 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 06:26 PM #2
phattyduck phattyduck is online now
96-98 is *VERY* different than '99-'02 in regards to the tailgate wiring. I'm assuming you are referring to a '99 based on your signature.
Assuming above is correct, here are the connections to the back door ECU that are easy to find (I may have missed some):
Pin# / Color / Function
3 / Yellow / Ignition Power (ECU-IG fuse)
1 / Blue / Constant Power
2 / Blue-Red / Ignition? Power (MPX-B fuse)
18 / Violet-White / MPX1 - multiplex communication wire
24 / Blue-Black / wiper motor negative
25 / Blue-Yellow / Wiper motor positive
22 / Gray / Wiper motor limit switch 2
23 / Gray-Red / Wiper motor limit switch 1
9 / Green-Red / tailgate control switch (rear keyhole for window up/down)
10 / Green-Yellow / tailgate control switch
13 / Red-Blue / back window limit switch (window has to be up for wiper functions)
26 / White-Black / Ground (white-black is almost always ground for Toyota)
11 / Red / back window motor
12 / Green / back window motor
4 / Pink-Green / to keyless buzzer (in engine bay, I think)
5 / Pink-Black / to keyless buzzer
Hopfully that helps.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
find , key , module , motor , power
HELP! Need Wiring Diagram for Flasher Module- Turn Signal Relay itsdchz 5th gen T4Rs 69 11-18-2019 05:46 PM
Second gen power window door module relay schematic needed FJvet Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-08-2018 09:06 AM
Wiring for relay module under the hood Tuc4R 5th gen T4Rs 2 09-14-2018 08:58 PM
Flasher module? Relay? simple 4th Gen T4Rs 6 04-14-2017 10:54 PM
1st & 2nd gen Rear Window Relay Module: Are they the same? Supermade Classic T4Rs 2 12-22-2011 05:38 AM
