Originally Posted by SeaBassHWD
Try it again (the method you did first) and when you press the lock/unlock button, manually lock/unlock it at the same time. This worked for me when my actuator wasn't strong enough to cycle the locks.
Thanks! I had the same problem as OP yesterday - received a different set of programming instructions that did not involve cycling through the locks. The seller then sent a new set of instructions that involved cycling the auto locks. My locks were also not fully engaging and your method worked for me.
