When I was changing the spark plugs on my 1996 T4R, I noticed that one of them had motor oil on the OUTSIDE of it. Because of the deep hole that the plug goes into, I could not see from where the oil is coming. What does that indicate ?
Thank you
Spark plug seals in the valve cover. Time to do a valve cover job on your truck. Check out this video that Tim and Sean did, it will have all of the information you need.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
