Old 07-07-2020, 03:51 PM #1
Dergibog Dergibog is offline
Dergibog is on a distinguished road
what is this housing with a hole in it?
On a friends 3rd gen, in front of the front seat passenger.
what is this housing with a hole in it?-6158413691-jpg  what is this housing with a hole in it?-6158413871-jpg
Dergibog is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 04:17 PM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
88502 - CASE SUB-ASSY, COOLING UNIT
88502-35130
( 1 )
LOWER (07/1998 - )
88502-35140
( 1 )
UPPER (08/2000 - )
Lower case is cracked, model year matters.
Old 07-07-2020, 05:00 PM #3
2002.
Is that lower housing ez to remove and replace?
Thanks!
Old 07-08-2020, 08:07 AM #4
Real Name: Mark
Real Name: Mark
Originally Posted by Dergibog View Post
2002.
Thanks!
Yes and No. Easy, everything is lightweight tools are small. Downhill from there, it's a PITA job.
Old 07-08-2020, 03:01 PM #5
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I just removed that box while i was replacing my evaporator and expansion valve. It's not too hard but you do have have unplug your ac lines in the engine bay that go into the firewall and into this box. Which that means you have to evacuate your AC and get it vacuumed and charged back up after. Might as well replace your expansion valve while you have the box open since it's a pretty cheap part. Would probably also replace the drier since you're opening up your AC system and that will start sucking in moisture. It's also a really cheap part.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 03:55 PM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I've never tried to remove that part on it's own, but even with the whole dash taken off it's a chore. Personally, I'd try and seal it up with some sort of thick tape or auto body filler then paint as long as your A/C is unaffected.
326WHP 347TQ
Old 07-08-2020, 04:13 PM #7
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
Yeah - to fix that, I'd say some black gorilla tape and call it a day... Otherwise you're going in... deep
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 04:22 PM #8
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
No need to take off the whole dash. I don't think it would even help much. It's not that bad for an under dash job. I just replaced my evaporator and expansion valve. The four bolts are a bit of a pain to get to, but it's way easier than most cars.
That said, some black duct tape would probably do the job.
My Backyard Frame Swap
Old 07-08-2020, 10:42 PM #9
Real Name: Mark
Real Name: Mark
I pulled the seat, center console, glove box for the room your gona want it.
You can get to it with glove box out that all the farther you want to go.
Expansion valve - - It aint broke don't mess with it, when it goes change broken box.
Make sure drain is working n Duck it !! what I'd do.
Here's another way to look at it.
Evac system, change drier at/ near 200k mi, get box out, clean evap of 20 years of sheite, change box.
3rd , friends , front , gen , seat
Injectors Interchangable: 4-Hole & 2-Hole? tbryanh 3rd gen T4Rs 2 01-25-2020 10:47 PM
2 hole or 4 hole injectors? neokhz 3rd gen T4Rs 17 02-03-2018 12:16 PM
Hole Runamok 5th gen T4Rs 5 07-26-2016 09:28 AM
What is this hole? TPC General Discussions 5 07-29-2014 10:31 PM
Butt hole moved after Body lift (Spare tire access hole) KSWAY 3rd gen T4Rs 3 03-13-2013 11:09 PM
