Old 08-16-2020, 04:26 AM #16
psea17 psea17 is offline
psea17 will become famous soon enough
Originally Posted by thennen View Post
I'll assure you that, if those brushes are original, they're about finished. Easy enough to check. May not be causing your problem, but a great preventive measure.
You were right! The alternator was on its way out! Problems persisted. Narrowed it down to a bad positive battery terminal and then foubd that the truck would immediately die when I disconnected the battery.
doing the cs144 mod this week.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:12 PM #17
pelantire pelantire is offline
pelantire is on a distinguished road
Originally Posted by psea17 View Post
Just to be clear. I'm not talking about the reduction in HP when the AC is engaged. I was just using that situation to describe the situation.
Since starting this thread, I just completed the Big Three+ Rewire. (alternator to battery+, engine block (oem location=beneath oil filter) to battery-, battery- to body (oem location), battery- to frame). The battery to frame was added because I'm running 2ga to an Anderson Plug I located at the rear trailer hitch area. The plug is grounded to the frame. The plug will have two uses: a) charge my trailer's batteries (a BlueSea ACR was installed at the truck's battery to disconnect when the truck isn't running; prevents the trailer from draining the truck's battery) and b) should I decide to use my winch, which will be mounted on a tray that fits into the trailer hitch, it will have all the juice it needs.
My alternator increased output at idle from 13.98v to 14.25v. Very happy. Will report on the window power draw a little later. I have not changed the alternator's brushes. But, I would guess based on the alternator's output, the brushes should be fine.
Appreciate any other insights.
What if the power window relays are wearing out?
pelantire is offline   Reply With QuoteReply With Quote
decrease , effect , engine , power , windows
Engine load after a lift and up-size of the tires Sifrk General Discussions 41 01-09-2019 02:30 PM
Really high end electrical load management... Whats out there? Bumbo Engines / Suspension / Wheels / Tires / Audio / Accessories 7 09-17-2017 10:28 PM
load leveler for installing engine baja1 3rd gen T4Rs 3 12-20-2016 03:52 PM
burning smell while descending under engine load masphx 3rd gen T4Rs 4 08-06-2013 01:03 PM
