Old 07-11-2020, 04:40 PM #46
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Originally Posted by Kanoe View Post
Those are the only two fuse panels.
Some guys here have wiring diagrams but not me, sorry.
In the back of the Chilton's Repair Manual, there are many wiring diagrams. Not that I know how to read them. ha Ha
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 07:54 PM #47
Originally Posted by sweet88gt View Post
I searched brushes and found most very cheap. I have an alternator pushing 13-13.3volts when hot. While I had it off I wondered why not replace the other items.
With the IAT temp at 127f I have 13.4v.
Old 07-12-2020, 07:51 AM #48
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
Interesting. I will check the IAT temp vs voltage as well.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 10:57 AM #49
That’s the closest I can get to guessing how hot the Alt would be.
My Cummins (with battery temperature sensors to determine charge rate) the other day was running 13.6v and in the dead of winter it pushes 14.7v.
Old 07-12-2020, 02:03 PM #50
118f iat and 13.4v today
Old 07-12-2020, 09:14 PM #51
Today I attempted to remove the alternator but I was stumped by the two wiring clips? harnesses? I can wiggle them just a bit, but I didn't want to break them by forcing them.
Is there some clip or locking mechanism that you must push with a tiny small screw driver. Chilton's Repair manual does not say. It just says, "Remove the wires"
Please advise
thank you
Old 07-12-2020, 11:17 PM #52
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
My 3rz alt has just 2 wires. One is the power connection. The plastic cover snaps off and a wrench takes the nut off. The second has a few small wires in 1 connector. It has a thumb tab to press hard on before you pull it out. This connector is the same locking mechanism as most connectors on the vehicle. No screwdrivers required but sometimes they are stiff.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 11:25 PM #53
Thank you very much, Kanoe.
I think the Chilton's Manual is miss-leading. The drawing is extra small and it LOOKS like there MIGHT be a screw to release one of them. So hard to tell from the drawing. But, I'll follow your advise. thanks again, pal.
Old 07-13-2020, 04:17 AM #54
I have a pliers with an angled jaw to squeeze those tabs and pull on the plug at the same time.
Old 07-13-2020, 06:18 AM #55
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Instead of wondering if your battery or alternator is charging, why not buy this for $50.
Amazon.com: KONNWEI KW600 Car Battery Load Tester Black Professional Automotive Alternator Digital Analyzer Waveform Voltage Test Tool for Vehicle/Boat/Motorcycle: Automotive
Tired of spending your money and time on expensive mechanics for routine check-ups on the cold winter? Would you like to self-diagnose your car battery correctly? The KW600 auto battery tester is exactly what you need and its the only battery tester which has a color screen!
One of my best auto purchases - test load of battery and alternator functions and tells you it working right or not.
You really want to run down to Autozone every time you think you have a charging issue? Gees!
Captsolo is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 02:11 PM #56
Would those be like bent jawed needle nosed plyers ?
Old 07-13-2020, 04:17 PM #57
Alternator problems ???
No they have a snub nose and two positions.
Edit.
Old 07-13-2020, 04:31 PM #58
sweet88gt's Avatar
sweet88gt's Avatar
Not to derail thread but mine at 104 Degrees IAT is 12.9-13 volts
Old 07-13-2020, 05:00 PM #59
Temperature control of the charging voltage happens inside the alternator - IATs won't be directly comparable. You'd have to have a temperature probe on the heat sink of the alternator electronics.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-13-2020, 05:37 PM #60
Yep, it’s as close as I can get to that. I just wanted to show what the voltage can go down to under really hot conditions.
alternator , auto , battery , runner , zone
270-XP alternator problems or issues? 4RExplorer 5th gen T4Rs 5 06-27-2019 01:48 PM
Alternator Problems? DanielMaat89 4th Gen T4Rs 4 07-01-2017 01:47 PM
22re alternator problems nykoda Classic T4Rs 7 06-27-2014 02:30 PM
Alternator problems... fo' runnin' Classic T4Rs 13 06-05-2014 05:21 PM
alternator belt problems kooooouuuumar Maintenance/Detailing 0 04-16-2008 12:21 AM
