Old 07-13-2020, 05:40 PM #61
Originally Posted by sweet88gt View Post
Not to derail thread but mine at 104 Degrees IAT is 12.9-13 volts
12.9-13 volts At where?
Battery posts?
What all is on at that voltage aka headlights, ac etc
Old 07-13-2020, 06:32 PM #62
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
I hit a brick wall trying to remove the alternator. 2 problems.
A.) the wiring connector on the end of the alternator , the one with a slightly square plastic clip, will not come off unless I break it off. I tried pressing on it with a tiny flathead and wiggling it. Tried to gently wiggle it off with needle nosed plyers. NO GO. DAMN!
B.) the tensioning bolt is neither 9 mm (too small) nor 10 mm (too big). I looked on the web but , so far I have not located any 9.5 mm socket or box wrench.
I f I can get that bolt off, I'll just cut the wires on the remaining plastic connector.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 06:45 PM #63
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
It seems weird that it would be an SAE bolt rather than metric, but 3/8" is almost exactly 9.5mm. I would give that a shot.
Skulking is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 07:38 PM #64
Try both pushing and pulling on the connector with the tab depressed. Worst case, you will be able to get a replacement connector.
Sometimes enough dust/dirt/grime gets in the connector to kinda lock it in place. I don't think you have access for this, but the other trick is to use a flat blade screwdriver to pry the connector open - many connectors have a spot where you can do this (push tab with finger, pry between male and female sides with screwdriver).
Don't try to remove your trans if you are having trouble with the alternator connector... things are even worse under there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-13-2020, 07:39 PM #65
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
Battery posts?
Battery posts 2 separate meters at idle no ac no load radio off
Pretty low
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 08:38 PM #66
Heaven knows what previous owners have done.
Old 07-13-2020, 09:58 PM #67
Pretty low
That voltage is bad imo.
Old 07-14-2020, 12:14 AM #68
Just returned from Dr. I must have surgery 1st thing tomorrow morning.
I hope to be back in a week or so.
Old 10-24-2020, 03:52 AM #69
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Ever get it straightened out? My alt fuse popped and alarm and dash lights are acting up too. Don’t know what happened before I wasn’t the one driving.
Pj Benn is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 08:31 AM #70
If anyone has the same issues with no accessories working replacing the alternator fuse will fix that
Old 10-25-2020, 09:44 PM #71
I managed to get the new alternator in. The wiring harness was a real bear to disconnect and I finally had to cut the wires and replace it with a new one.
Anyway, problem is solved.
alternator , auto , battery , runner , zone
270-XP alternator problems or issues? 4RExplorer 5th gen T4Rs 5 06-27-2019 01:48 PM
Alternator Problems? DanielMaat89 4th Gen T4Rs 4 07-01-2017 01:47 PM
22re alternator problems nykoda Classic T4Rs 7 06-27-2014 02:30 PM
Alternator problems... fo' runnin' Classic T4Rs 13 06-05-2014 05:21 PM
alternator belt problems kooooouuuumar Maintenance/Detailing 0 04-16-2008 12:21 AM
