Old 07-09-2020, 12:38 AM #1
roger65 roger65 is offline
roger65 is on a distinguished road
Complete front strut assembly recommendations
I will be replacing the front struts on my daughters 96 4runner in the coming weeks and am looking at doing a complete strut assy vs reusing the stock spring as the rig has 300k miles on it. I am assuming the struts on there now are the stock ones since they say Toyota on them and the lower bushings in them are toast. I see unit from Monroe, Gabriel, Moog, GPS, and Summit. Anyone have experience with any of these? Will be doing rear shocks at the same time as well.
roger65 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 08:51 AM #2
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
I wouldn't put Monroe or Gabriel shocks on my truck if they were giving them away and throwing in a free gas card.
I wouldn't use any of those brands. Personally, I'd go with Bilstein or KYB.
tvpierce is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:06 AM #3
I had great luck with the Gabriel’s on all 4 corners.
Old 07-09-2020, 02:22 PM #4
She has a pretty strict budget, that's why we are looking at those brands. I figured at 300K miles the springs could use replacing as well.
Almost anything has to be better than the clapped out stock units.
Old 07-09-2020, 02:32 PM #5
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Installed Monroe Quick Struts on a GX470 (same platform as a 4th-gen 4Runner) almost 2 years ago (August 2018) and so far so good.
Definitely shop around, I just happened to have some rewards $ from Advance Auto plus a 25% discount code at the time which ended up costing less than any mail order source
Old 07-09-2020, 04:36 PM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Why not consider KYB shocks and moog springs? Get someone to preassemble for you. Those are generally considered good basic parts. Lots of info available about folks using both, cheap at r*ck auto.
Personally, I’ve never had Monroe’s last over 6 months. They don’t seem to like cold and start knocking.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 06:59 AM #7
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@roger65 , I've used KYB adjustible's on a car held up fine for the 30-40k miles I kept it. Been mentioned here using Moog springs people were positive about ride, no long term info, I'm guessing 40k +-mi they be done, for the price not bad.
As for paying for assembly, why do that ? Just saying.
Just installed Billy Tundra 6112's big diameter, long. Shop's wanted $130-50 some wouldn't touch em, hook compressor no go. I Used LCA, Floor jack, weight of vehicle to assemble struts on vehicle, easiest way I've ever done it, cheap. Had slow controllable speed, power, 3 axis rigid frame keeping things straight as you guide parts in place till stem is through top hat, bushings compressed, put stem nut on torque it. Safety always a concern messing with springs. Felt safer more in control of job than I ever felt using hook or floor stand type compressers.
Old 07-10-2020, 07:23 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
In my case, I replaced with Manoe quick strut and that was a major mistake. (Tentanus 1.) Not even remotely close to OEM struts. I did this 5 years ago and regretted it ever since. I definitely would go with another combination.
On a side note:
The OEM struts are extremely expensive because Toyota lifetime warranty them if you have a dealership install the shocks and struts as well as their exhausts. However, they do honor it and will replace the shocks and struts etc. If they leak.
Old 07-10-2020, 08:15 AM #9
Real Name: Mark
Real Name: Mark
I used Monroe about a 100 years on a 68 Camaro, junk then would imagine junk now.
Old 07-10-2020, 09:12 AM #10
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
May want to check out pricing on the KYB’s as I went with them at all 4 corners and have been very happy with the results.
They are reasonably priced and in my experience offer similar ride/handling to the originals.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 10:40 AM #11
drallan drallan is offline
drallan is on a distinguished road
On a side note:
Brillo. What did you disconnect to do this? I've thought about it myself as I have a pair of KYBs and Moog 99 talls waiting for install (when I get around to it). I've see it done on the 4th gen by just disconnecting LBJ, but I'm not sure why the same approach couldn't be taken on the 3rd gen. However, it doesn't seem to get much traction.
My thought were:
1) Jack up vehicle and place on jack stands
2) Support LCA w/ jack and provide a bit of up pressure.
3) Remove lower shock mount bolt
4) Remove disconnect OTE and Sway bar link
5) Remove LBJ (either castle nut or 4 bolts) (might replace anyway as mine are 5 y/o 555s.
6) Remove 3 nuts holding old assembly in place
7) Lower LCA jack and remove assembly as a whole.
Install would be basically reverse.
1) Install Top hat into truck
2) insert spring
3) insert shock
4) reinstall lower shock bolt
5) jack up LCA and compress spring
6) attach top shock nut
7) re install LBJ, OTE, SB
8) Tighten everything up
drallan is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 01:04 PM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
My thought were:
2) insert spring
3) insert shock
it would be nice to see a youtube video of this being done on a 3rd gen 4runner...not 4th gens and not other cars
Old 07-10-2020, 01:50 PM #13
What parts are required for such work? strut, which spring, and what are the other parts required? I have never done this type of work before. I did just do her ball joints. She does have a Revtek leveling kit on the front. Does this go away then? The main reason I want to do all is because the rig has 300K miles on it and it appears the struts are stock units so I am sure the springs will be all slacked out. It is her daily so it has to be done in a day.
Old 07-10-2020, 03:12 PM #14
Front springs don't seem to sag with age, so they are probably fine.
Rent some spring compressors (free from autozone) and you can swap everything over. If you live in the rust belt, you will likely need some replacement hardware.
If the Revtek kit you have is just the preload spacer, you will be 'fine' with whatever shocks you choose. If you have a top-out spacer too, then most of the non-OEM shocks will be too long to fit the top spacer.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-10-2020, 04:34 PM #15
Real Name: Mark
Real Name: Mark
What parts are required for such work? strut, which spring, and what are the other parts required? I have never done this type of work before....
Read this: 3rd Gen 4Runner Lift Information, small section on stock stuff.
Grab a 3rd Gen FSM off the net read it. Section SA-51 starts strut replacement.
At 300k I'd replace all springs n shocks with a aftermarket set for a 99 tall brand of your choosing.
Not a complicated job, easier you outside of rust belt, everything go right easy day job doing both ends first timer could be longer.
Front hiccup free most times, rear shock stem nuts in bad spot stem may need cutting off.
complete , front , stock , strut , struts
Front strut assembly issues Berty_K 4th Gen T4Rs 4 06-30-2019 09:53 PM
MOOG Front Complete Strut Assembly (ST8595L/R) DK327 3rd gen T4Rs 1 04-13-2016 05:57 PM
09' FJ 4x4 Complete Front Strut Coil Assembly w/o 3" spacers Oneluv13T4R For Sale: Suspension/Wheels/Tires 5 09-04-2015 11:31 AM
WANTED: 2007 FJ complete Strut Assembly trayscool For Sale: Suspension/Wheels/Tires 0 12-27-2014 03:24 PM
