Old 07-10-2020, 10:08 PM #1
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
32x11.5 on stock 15" wheel
If it would rub where would a 32"x11.5" tire rub? This would be on the stock 15" wheel on a stock 2002 4Runner. On the body/frame or on a suspension component like the spindle/control arm? I am considering this tire size if would clear the suspension components. I do not have an issue with hammering/modifying the body or cutting a fender.
I will be wheeling this truck just as much as it sees the road so the tire would have to be able to go through the entire suspension range without rubbing.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 08:24 AM #2
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
It will fit. Try it. It may rub a little. But probably just need to trim a little on the fender liner bump out at the pinch weld, and you can sledge back the pinch weld. I'm running 285/17 with a 1 inch body lift on 99 tall springs, and that's what I had to do cause it had just a tiny bit of rub.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 01:30 PM #3
Can you please clarify the exact tire size you are are using with what size wheel and backspacing
Old 07-11-2020, 04:33 PM #4
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Factory offset and backspacing, Toyo Open Country A/T II, P285/70R17
My tire exact size is 32.8"X11.5" according the tire size calculator.
You can check out their site, its a good reference for tire sizes.
tiresize . com
Old 07-16-2020, 11:07 PM #5
The original question is pointless as you can't mount an 11.5" wide tire on the stock 7" wide rim. You will need at least an 8" wide rim to mount the 11.5" width. Clearly wasn't thinking this one through. Duh.
32x11.5 , rub , stock , suspension , tire
stock 15" **IFS** wheel dimensions? 89FourRunner Classic T4Rs 4 03-17-2016 05:36 PM
2" OME lift with 32x11.5??? 95yotarunner619 Classic T4Rs 8 10-09-2013 10:45 AM
32x11.50x15 on stock '96 SR5? Dezert4Runner 3rd gen T4Rs 7 07-22-2011 06:14 PM
265/75/16 vs. 32x11.5 15 any wheel experts? Jared Pabis 3rd gen T4Rs 15 01-16-2011 07:19 PM
2" BL + 3" suspension + stock wheel = biggest tire? Magnum 3rd gen T4Rs 15 11-16-2009 01:23 PM
