Old 07-10-2020, 11:07 PM #1
dkerr's Avatar
dkerr dkerr is offline
Real Name: Daniel
dkerr is on a distinguished road
dkerr's Avatar
Real Name: Daniel
Pesky Oil Leak
A couple weekends ago me and a friend tackled the valve cover gasket jobs on my 2000 4runner and his 1997 Tacoma. We went the full 9 yards and bought all OEM Parts. Half moons, cam plugs, gaskets, Toyota FIPG, spark plug tube seals. The real timmy the toolman package.
Both of ours had slight leaks before the job and I was hoping to fix this and not have to smell burn oil at red lights anymore. But as fate would have it I drove it around a while and I still smell that oil burning on the exhaust. On top of that I've notice oil is slowly dripping on the garage floor (however i did an oil change the next weekend and suspect I just need a new washer on my drain plug).
Anyways, I'm pretty inexperienced with oil leaks so I wanted to know if yall had any input on how I should go about locating where its leaking. I did some poking around tonight to see whats wet and what not and tried to clean a little but I'm gonna take a closer look at it tomorrow. Any help would be greatly appreciated.
Thanks!
dkerr is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 12:20 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
So you are Sure the new job is leaking? (pics please)
I mean it had all kinds of built up oil dripping very slowly for a long time, it will take time for all of that to finish its 'journey' through many areas some on the exhaust and some on the lower engine/trans. Careful if you decide to wash the engine, I'd stick to steam, no cool water. Luck.
Old 07-11-2020, 12:51 AM #3
dkerr's Avatar
Real Name: Daniel
dkerr's Avatar
Real Name: Daniel
Yeah it's possible that I'm smelling residual oil from the initial leak. there is still oil dripping onto the ground but im hoping thats the drain plug.
__________________________________________________ ______
2000 Toyota 4Runner SR5
3in Toytec/Eibach Lift
265/75R16 General Grabber ATX's
Old 07-11-2020, 01:01 AM #4
dmppdx dmppdx is offline
dmppdx is on a distinguished road
Two other common, and easy to fix leaks, are the oil dipstick gasket and the oil cooler gasket. The oil dipstick is at the bottom of the tube the dipstick goes into. The oil cooler is the round thing on the left side of the engine slightly behind the oil filter and their is a gasket that seals it to the side of the engine. Neither would drip on the exhaust, but both could drip oil on the floor.
dmppdx is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 01:15 AM #5
dkerr's Avatar
Real Name: Daniel
dkerr's Avatar
Real Name: Daniel
Awesome, Thanks. I'll check those.
Old 07-11-2020, 10:32 PM #6
dkerr's Avatar
Real Name: Daniel
dkerr's Avatar
Real Name: Daniel
Took off the skid plate and looked around. Pretty positive the drip is the plug. It seeps out minutes after wiping it.
Found this strange cardboard/paper piece wedged between the skid plate and frame cross member. Couldn't get attachments to work on the website so heres an imgur link: Weird Piece - Album on Imgur
Cu
Old 07-12-2020, 01:03 AM #7
jgue467's Avatar
jgue467's Avatar
Well if oil is newish, try tightening or new gasket. May want to get one of these, with a hose attached (tuck it up when not in use) it sure makes oil changes far less messy and you don't have to remove skid pan to avoid oil drips on it:
Amazon.com: Fumoto Original F103N with LC-10 Lever Clip FN-Series Engine Oil Drain Valve, 1 Pack: Automotive
Old 07-13-2020, 09:50 AM #8
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Cu
Cardboard piece is likely there to direct any oil that makes it's way onto the skid plate. Could also be for noise isolation.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 07-13-2020, 10:01 AM #9
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Switch back to 10W 30 brand name conventional oil if you are using synthetics.
Captsolo is offline   Reply With QuoteReply With Quote
drain , leaks , oil , plug , smell
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
leak fun T?@\7 Classic T4Rs 0 10-02-2010 07:49 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
