Old 07-11-2020, 08:07 PM #1
dommmmyg dommmmyg is offline
dommmmyg is on a distinguished road
New OEM Power steering pump -- still whines
Hi everyone,
I've done a fair amount of research on the power steering pump whine issue and am curious if anyone can help point me in the right direction for my particular situation.
I followed the DIYs -- flush the fluid until clean with new ATF, pull the reservoir off and clean the screen, neither solved the issue.
I thought ok, I might as well replace the pump. At 260k miles maybe the original unit has had enough. So I just installed a brand new OEM pump and the whine persists. I made sure to flush the system again before installation so the new pump had fresh fluid, and the level is correct and consistent for both cold and hot ranges. The noise is clearly the PS pump as the groaning noise intensifies as you turn the wheel left to right.
I haven't come across anyone else that's had the issue after a pump replacement, so I'm curious what would the next steps be? I'm using Valvoline MERCON V fluid (Dextron III compatible) maybe try a different ATF? If I remember others have suggested a rack replacement but I don't see how that would be necessary unless there are orifices of some kind that are blocked in the rack/lines. Seems unlikely.
Please let me know what you guys think, thanks!
dommmmyg is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 08:29 PM #2
6uam671_T4R 6uam671_T4R is offline
6uam671_T4R is on a distinguished road
Try to bleed the pump. Cycle the steering wheel full left and full right several times. I had the same issue and did that which resolved the groaning.
Hopefully that helps with your situation.
6uam671_T4R is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 11:08 PM #3
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
We had a 2001 Ford Windstar with a whine from the Power steering. The dip stick level indicator was wrong. Only figured this out after throwing parts at it. It became quiet when slightly over filled.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 10:49 AM #4
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
I suggest you try a different fluid. Ironically, I had the same problem after 320k miles of using only clear P/S (like Prestone) and then switching to ATF on original P/S pump. When I switched back to P/S fluid, the groaning went away...go figure!
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 11:56 AM #5
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Is the fluid foamy at all? If air is entering the system somewhere it will whine like that.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 01:03 PM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
You can try and bleed the system, run the engine for about five minutes, then shut it off for 20 to 30 minutes. Then come back and top off if need be, then drive it. Check it again for bubbles.
Also try releasing the tension on the drive belt every so slightly. If it increases in noise, tighten it. May need a new belt, had the same problem on a 97 Camry.
I have used Maxlife ATF in all Toyotas with great results.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:19 PM #7
Thanks for all the responses, guys! I finally had some time to dig into it a bit more yesterday.
I 'bled' the system again, checked the fluid for any foam, and verified the level was ok without any improvement to the noise.
But to be honest, after some thinking I don't believe the issue is the PS pump after-all. I theorized it was pump because the groaning noise is highly influenced by the steering but after putting my ear around the engine bay, the groan is loudest on the underside of the vehicle. I noticed the frequency of the sound is also influenced by the gear position, which leads me to believe it's a transmission issue. I've seen others conflate the two in the past and I believe I did the same.
Anyway, I did a full flush of the transmission 6k miles ago and ensured the fluid level was correct.. I guess it's time to dig into a manual swap.
Old 07-27-2020, 02:36 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would temporarily take the serpentine belts off and see if the noise is still there. That should help verify that it's not the power steering pump or alternator
Old 07-27-2020, 03:15 PM #9
good idea!
fluid , issue , pump , replacement , steering
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Is my power steering pump going bad? radlynx 4th Gen T4Rs 21 12-19-2017 07:30 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Powersteering pump whines when brakes applied carl johansson Classic T4Rs 2 10-30-2010 09:24 PM
