Old 05-18-2023, 08:38 AM #16
sneezye sneezye is offline
Real Name: Ben
sneezye is on a distinguished road
Real Name: Ben
Originally Posted by TheDurk View Post
That bolt is p/n 90119-10825 *** STD. PART. The 10 right after the hyphen means it is an M10. Toyota M10s are usually 1.25 thread. This list has never done me wrong:
Thank you. That's exactly the info I needed.
2002 Limited
Golden Pearl
sneezye is offline   Reply With QuoteReply With Quote
Old 05-21-2023, 12:27 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is what those bolts look like from behind.
Old 05-02-2024, 02:13 PM #18
BMATA5 BMATA5 is offline
BMATA5 is on a distinguished road
Actually, on that particular bolt, this may not be the best approach. It's probably not stripped, rather the thread has corroded and the weld-nut has broken free from the sheet metal of the floor contour it is welded to. This is pretty common. You can try the pry bar, but it probably won't work and if you force it hard with the pry bar, you will just rupture the sheet metal and do more damage to the floor. Pressure with the pry-bar is unlikely to secure the nut if the sheet-metal could not hold it,
There is no easy way. I would try to dremel the head of the bolt off. You could also drill the head off, but it might spin on you. If you have to, then just go violent and just pry the base up without trying to turn the bolt until the nut busts through the sheet metal. Then you still have to cut the bolt out of there.
The fix is easy. Just get a longer bolt and drill through the lower floor and put a nut and a big fender washer on the underside of the truck. Cover with RTV to seal. That's worked fine for me and many others.
Some people of the OCD persuasion have welded in new sheet metal or inserted a new nut through a slot cut into the side of the contour. Search and you will find them.
Thanks for this fix TheDurk I have really never drilled through metal like this before. Does it require a special drill or bit? Any advice about the procedure is most welcome!
BMATA5 is offline   Reply With QuoteReply With Quote
Old 05-02-2024, 07:48 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
"Thanks for this fix TheDurk I have really never drilled through metal like this before. Does it require a special drill or bit? Any advice about the procedure is most welcome! "
To drill out the bolt. You will need a metal drill bits. Start with a small bit and slowly drill through the bolt in the center. Then increase the size to 3/8 as 10mm is just slightly larger then 3/8 inch so the next size up is mostly 7/16 which is the largest bit you should need.
Once, you have it drilled out you can decide what method for fixing your bolt. :-)
Old 05-03-2024, 11:53 AM #20
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Yeah, that's it. You will probably need to hold the bolt head with Vise-Grips as the drill will make it want to spin. Truth is, if you get the other bolt out, and then lean back hard against the seat, it will probably pop out. Then you can get a Sawzall on it. This is probably the easiest way if it works.
My Backyard Frame Swap
Old 05-03-2024, 01:26 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah I forgot the vice grips. Thanks for the update TheDurk greatly appreciated. :-)
Old 05-03-2024, 02:35 PM #22
If you can get to it with a vice grips is the metal good enough to mig the bolt back into place?
The heat will probably allow you to back out the bolt.
Old 05-03-2024, 03:26 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sometimes... Mostly they pull out but, I have seen the nut break loose in the back and you have to take the head off to get the but and reset of the bolt out. Lots of ways to fix this particular issue, so its up to the rig owner on how to fix it. Nothing wrong with mig if they want to go that route.
The metal bracket wasn't thick enough and there isn't any backing by the nut. If Toyota would have even welded a big washer in before the nut. These bolts and nuts wouldn't have had any issues. Slight design flaw. :-(
Old 05-04-2024, 07:00 PM #24
TheDurk's Avatar
TheDurk's Avatar
The Vise-grips go on the head of the bolt. To mig the thing, you would have to get underneath the seat leg where the weld nut and floor meet. That would take a lot of clearance. If the bolt did not back out at all before the nut broke free, it would be impossible.
So you have three choices: 1) Drill out the head of the bolt; 2) Manhandle the the nut through the hole in the floor and put a Vise-grip on it; or 3) Cut the bolt stem if you can get to it. This last was my case. I was able to get a few turns on the bolt before it locked up and the nut broke free. I was then able to get my Dremel cut-off wheel on the stem and cut the head free. A grinder might work, too.
I am open to more suggestions but I think they will all be variations on the above.
bolt , removing , screw , seat , thoughts
Rear Seat Bolt Stripped - HELP TheDozer 5th gen T4Rs 13 05-15-2018 01:43 PM
stripped bolt hole eanema 3rd gen T4Rs 15 11-20-2015 08:28 PM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Help stripped head bolt 22R AKcharger Maintenance/Detailing 3 01-06-2013 12:58 AM
Stripped bolt chunderboy Off Topic 7 06-04-2005 01:23 PM
