Old 07-13-2020, 04:43 PM #1
Jay4runner7 Jay4runner7 is offline
Jay4runner7 is on a distinguished road
Flipping tires inside out
Hello, I have a set of KO2 all terrain tires with the white lettering out. I noticed how they get dirty quick when I go off-road. So I was wondering if I have 10k miles on them if it would be fine to flip them so the white lettering is inside. Thanks
Jay4runner7 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 04:49 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Perfectly fine to do so. Would obviously require them to be rebalanced after remounting with white letters in, but that would be included in the price of mount and balance 4 tires.
Old 07-13-2020, 05:05 PM #3
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
White letters are too cute for me. Since they are seasoned at particular forward rotation direction, best to keep that in mind when flipping them on the wheel. So basically swap swap drivers side with passenger side.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 05:51 AM #4
That’s good to know, I thought if you get to a certain mileage it’ll be too late to flip it.
Old 07-14-2020, 12:31 PM #5
Real Name: Patrick
Real Name: Patrick
I disagree with that. The most recommended tire rotation pattern is a modified x. For a RWD/4WD that would be the rear tires to the front on the same side and the front tires going to the rear but on opposite sides.
Old 07-14-2020, 12:58 PM #6
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I think the best case scenario for tire rotation would be to flip the tires on the rims and rotate sides of vehicle. That way inside was out and rotation direction changed.
But of course pulling 4 tires off the rims every rotation would be silly.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 08:16 AM #7
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Ok, maybe you got that recommendation cause they want to sell more tires. Well just to let you know I just got over 100K on a set of Toyos on my 3rd gen, doing what I do. Thats also not the 1st set I had cross over 100K either.
Here's my recent post.
Over 100K on Toyo Open Country tires on my DD 3rd gen
Old 07-15-2020, 09:09 AM #8
Real Name: Patrick
Real Name: Patrick
Congratulations on that. I on the other hand have had tires last much longer with regular modified x rotations. I'm glad you found something that works, but I guess we'll never know which is better because I'm not going to rotate my tires your way, and I doubt you will rotate your tires my way. I think we can agree that rotating your tires with either method is better than not rotating your tires at all. It's very obvious by tire wear which customers never rotate their tires.
Old 07-15-2020, 11:12 AM #9
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Flap disc on an angle grinder will erase the white letters quickly.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 02:10 PM #10
pauldub pauldub is offline
pauldub will become famous soon enough
40 years ago you weren't supposed to change the rotation of radial tires. It's not 40 years ago anymore and things change.
pauldub is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 04:30 PM #11
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
Yeah whatever works is good, everyone is different. All different factors, tires, driving type, vehicle type, roads, climate.
Old 07-15-2020, 04:31 PM #12
dogtail's Avatar
Real Name: Keith
dogtail's Avatar
Real Name: Keith
How about a big Sharpie?
flipping , inside , lettering , tires , white
Tires wearing bad on the inside purevenom1 Classic T4Rs 12 10-11-2012 05:31 PM
Inside balancing for Tires?? Nuttymopar Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-18-2005 05:44 PM
USA Today on SUV's flipping over Kanab 4th Gen T4Rs 12 08-08-2004 11:57 AM
flipping tires around kingidivine 4th Gen T4Rs 6 07-07-2004 07:56 PM
School Bus Flipping Video! Thai Off Topic 0 11-18-2003 02:18 AM
