Old 07-16-2020, 03:59 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by 96TrailSurfer View Post
I am going to try 2 things:
- find a 97+ yoke from an auto-wrecker and depending on its state, combine parts with mine - key is getting a spring
- double up on the wave washer
I didn't try doubling the wave washer, but I can see how it would help.
If you get your hands on a mid 97 to 2002 (which is a different part number than the one we are discussing) I'd like to see what has changed and if any parts can be updated in the old shaft.
I think the main difference is the top joint to the steering shaft. I think it's smaller diameter in our old ones that do not have the slidey, collapsey bit in the column.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 12:21 PM #17
DirtDrift DirtDrift is offline
DirtDrift is on a distinguished road
Any updates on this? I'm currently working on two 2002's that are experiencing the exact same issue. Steering clunk over bumps when turning. I'll follow this thread for updates.
DirtDrift is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 03:08 AM #18
96TrailSurfer 96TrailSurfer is offline
96TrailSurfer is on a distinguished road
I got distracted with a blown alternator (courtesy of swimming in a mud pit), which is a PITA since I have a Surf and not a 4runner, and finding an NA cross-over part can be a pain.
My plan, however, is to first try doubling up the wave washer and, failing that, a rag joint from a later model.
I'll update here when I do this.
96 Hilux Surf - 1KZ-TE (EGR delete, turbo boost controller, catch can), 2.5" lift in the front (Tundra Bilstein 5100s, Eibach 620#, and SPC UCAs), 3.5" lift in teh rear (Fox racing 2.5 remote resi adjustable 3rd gen Taco shocks and LC 8.5 wrap coils), 1" body lift (4crawler), ARB bumper, with SmittyBilt XRC 9.5k Gen 2 winch, 33" KO2s, D2S projector retrofits
96TrailSurfer is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 07:22 PM #19
96DesertRat's Avatar
96DesertRat 96DesertRat is offline
96DesertRat is on a distinguished road
Interested in the outcome as well. Subscribed Steering Column Rattle / Clunk
Sent from my Pixel 2 using Tapatalk
96DesertRat is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 07:25 PM #20
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
+ Subscribed
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 05:47 PM #21
papabear1126's Avatar
papabear1126 papabear1126 is offline
papabear1126 is on a distinguished road
Between Kanoe and you I may Finally make some headway. This has been driving me crazy for years now.
I have two "97s" manf 8/96 and 10/96.
The manf 8/96 is a Limited Automatic and has had this slight wander on the highway and I have spent countless hours only to nail down what only you two have mentioned.
The differences in the 96s in the steering! Months and videos and countless research till today!
I have changed Almost everything else except the rack itself because I read to many times guys spent all that on oem rack, hoses, etc and Still have the issue!
Yes I did all the other things minus the tilt ball shim and change the lower rag joint.
So, IF I read this right, my only real option is to hunt the yards to find a 97 with the updated better spring?
I am not buying the entire:
45290-35030 Yoke Sub-Assy, Steering Sliding $311.23 W(TILT STEERING)
Production Date:11/1995-06/1997
Fitting Vehicle Options: RZN18#, VZN18# Part Name Code:45209
It says "Replaced By:45290-35031" but that says discontinued!
So, I guess I have to go spring hunting? No luck on the part # if any for the parts discussed?
Read beyond the tack weld too, ty Kanoe. Good thing I read till the very end because I nearly ordered the LC 100 part out of FL.
I will take and post any pics etc of what I find. The differences mentioned etc.
Please! Keep this alive and updated as I am sure Many like us have not gotten this far that have the older version.
WTG on the posts!
97 4Runner Limited 183+K
97 4Runner SR5 308+K Never A Breakdown
Best Vehicles I Ever Owned
Jim Thorpe, Poconos PA.
papabear1126 is offline   Reply With QuoteReply With Quote
Old 04-08-2022, 03:50 AM #22
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
is it confirmed that the p/n 45290-35040 can be used on 96-97 4Runners?
Has anyone with a 96-97 used this part number as a replacement?
OK, so I did some more digging and exploring
The part in issue is called a yoke subassembly, for which I found at least 3 interchangeable part numbers:
45290-35030 - all 3rd gen 4runners
45290-35031 - all 3rd gen 4runners
45290-35040 - all 3rd gen 4runners, a 1st gen tacos
Toyota lists it as a single, non-use serviceable part.
Since I had a spare shaft, I opened the yoke and I think I may have an idea of what's wrong.
The OD of the circular plastic disk is 2-4mm less than the ID of the metal carrier. Not sure why it's designed this way, but perhaps the rag joint made up of a steel lined hole on each side of the desk receiving a steel ball needs some degree of free motion.
Keeping it against one of the carrier surfaces is wave washer (OD = 60 mm, ID is 57 mm, free height = 3 mm). Without the wave waher, the whole assembly rattles like a sack of nuts. With the washer in place, the whole assembly is noticeably tighter, although it still rattles quite a bit in this (video ) since I cleaned out all of the (24 yo) grease.
So, I wonder if the following may do the trick:
- a new, preferably beefier wave washer?
- an o-ring around the plastic disk? - don't think it would survive long
- heavier grease?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 02-11-2024, 01:12 PM #23
DJ907 DJ907 is offline
DJ907 is on a distinguished road
Seems like we never got a resolution of this issue. ‘98 here, same problem (I think) running new ball joints, inner/outer TREs and bushings. Would love to hear the fix!
DJ907 is offline   Reply With QuoteReply With Quote
Old 02-11-2024, 02:44 PM #24
SocalRunner15 SocalRunner15 is offline
SocalRunner15 is on a distinguished road
How are your lower control arm bushings? If they're shot....what you described will happen.
SocalRunner15 is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 03:11 PM #25
ninethings ninethings is offline
Real Name: Tim
ninethings will become famous soon enough
Real Name: Tim
Hittin some washboards pretty hard this weekend my rattle got a good bit more pronounced. Used to have to listen for it, now I cant really ignore it.
Hoping what you're suggesting is the culprit. My lca bushings are all but shot, have a new set of lca's and bushings ready to install, just need to find the time.
Everyone in this thread is contemplating trying 98+ components to rectify their issue. Thing is... I have a 2002 and have the EXACT same issues as being described here. Going to cross my fingers and hope the new LCA's remedy the issue. Really dont want to dig in to the rack/column
<a href=https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEhRUBHdN4dX3N-MZqnf4MmbxaF1QVQ8kLoGcbvEX3SNwSyV_geqoX9F5LACC8BWf7UQIBzi5AC5qHBgksRfky-s3P1k9Pp-70LTMpPzK__f2bK2f30sbQq_zRuN3Cqwx93feDQ9Ndb2dQav6nodFdYVRSNBnDFeeSfFIiVfUq0VyQ3yYr93Gg0IjfTdAO0/s320/IMG_4239.jpeg target=_blank>https://blogger.googleusercontent.co.../IMG_4239.jpeg</a>
ninethings is offline   Reply With QuoteReply With Quote
joint , mod , play , steering , truck
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
Can't disconnect steering column from steering rack variablevalve 3rd gen T4Rs 8 05-25-2017 01:30 PM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
Knock/Rattle in steering column or front end Dustin4185 4th Gen T4Rs 0 03-03-2012 11:17 PM
