Old 08-03-2020, 06:10 PM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Vampire draw
How long will a new battery last long enough to start the truck if it is just sitting and not being driven ? I only use it a few times/month . Anyone know if the computer and clock will drain the battery in 2-3 weeks ?
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 06:21 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Kinda hard to tell… but you should be able to make it 2-3 weeks without help. The draw might vary from truck to truck, especially if you have aftermarket accessories, along with your battery health.
A small 20 watt solar panel on the dash and a cheapie charge controller will do wonders for you. That’s how I have been keeping my car healthy because I don’t have an outlet for a battery tender.
Old 08-03-2020, 06:59 PM #3
It *should* be fine for 2-3 weeks at a time. But the 'recharge' drives will have to be for some time - the battery takes more than a few minutes to recharge.
I'd second the suggestion for either a Battery Tender (or similar trickle charger) or a small solar panel, depending on the parking situation.
edit: I personally try to have a battery tender on any of my cars that get parked for more than a week.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-03-2020, 10:42 PM #4
Hmm, great idea. I never thought of that. I looked on Amazon and they have a few that cost only $25. Apparently, they just plug into the cigarette lighter and do not need to be clamped onto the battery.
Old 08-03-2020, 10:59 PM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I spend much of the winter in Brazil, normally. Frequently I leave the truck for two, even three months. I just pull the battery negative. When I come back, pop it back on, she starts right up.
My Backyard Frame Swap
Old 08-04-2020, 02:22 AM #6
Does disconnecting the battery foul up your computer programs ? Mess with idle speed etc ?
Old 08-04-2020, 04:18 AM #7
Our cig lighter is not hot with key off so you would need to hardwire your cig lighter directly to the battery to do that.
Depending on engine condition, disconnecting the battery to store your vehicle may or may not cause low idle/drivability issues while it relearns it’s adaptive parameters.
Old 08-04-2020, 07:47 AM #8
TheDurk's Avatar
TheDurk's Avatar
It relearns quickly. I barely notice anything being off, if at all. Biggest problem is the time and radio presets on the head unit.
Still a lot better than a dead battery.
Old 08-04-2020, 10:33 AM #9
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
It shouldn't, if it does you have other problems.
96Red would sit from 21 to 36 days at Heliport while I did my hitch.
One time in 10 yr it didn't start, 5 yr old Battery was done.
Old 08-04-2020, 12:35 PM #10
It is pretty easy to put a jumper wire in one of the relays in the engine bay to have the lower two (and back hatch) plugs hot all the time. No permanent vehicle changes needed.
Old 08-04-2020, 01:25 PM #11
Bumbo's Avatar
Bumbo's Avatar
I back-feed thru my 12v cig/accessory jack. Very convenient way of using a solar tender inside the car.
Old 08-04-2020, 04:45 PM #12
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
For me I have found that through experience usually an AGM battery will not lose its charge as quickly as a lead acid one so that may figure into your future plans if your 4Runner sits for some time.
If not, another vote for a battery tender of some kind.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:53 PM #13
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I've used my battery tender more times than I can count, WELL worth my money. Been a life saver at times.
Batteries can be a real crap shoot. One time I did a timing belt job on a early 00s Civic (maybe it was a 90s Sentra?) that was sitting for well over a year and it started up somehow on the old batt - then there was another time back in high school I replaced the one in my Dakota on a sunday, went to class on friday, came out at lunch 4 hours later and it was dead as a doornail. Couldn't find a drain on it, and Napa even ended up giving me a free replacement for it. It's ALWAYS smart to keep a tender around, it can be a real ace up the sleeve
battery , computer , long , times/month , vampire
** Price Drop** Surefire Mini Scout and Surefire V1 Vampire (Vancouver,WA) jbstrd For Sale: Non-T4R Items 2 02-24-2018 01:42 PM
normal amp draw jerrysc99 4th Gen T4Rs 8 08-07-2009 12:26 PM
Parasitic Draw in JBL amp cotten Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-15-2008 01:09 AM
Where do you draw the line for a DD ? Falls 4th Gen T4Rs 9 07-27-2007 11:05 AM
How to Draw a Woman Thai Off Topic 7 12-16-2006 11:15 AM
