Old 07-14-2020, 11:12 AM #1
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
What else to do while front diff and LCAs are out
Hi guys,
I'm about to tear into the front end of my 3rd gen to replace the front diff and LCAs (poly bushings). I'm going back with new OEM LBJs and new bolts while I'm there. Also doing new alignment cams and bolts.
Anything I need to consider replacing while I'm that far into the job with all of those parts removed?
Already new:
CVs, Steering rack, intermediate shaft, inner and outer tie rods, durobump diff mount bushings, wheel bearings, brakes, brake lines.
Anything else I may be missing? In other words, once I install this diff, I really dont want to have to wrestle it back out ever again haha
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 11:22 AM #2
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you have the front diff out, consider dropping the oil pan and resealing it if it shows signs of leaking. The oil pan can't come out unless the diff is out of the way.
mtbtim is online now   Reply With QuoteReply With Quote
Old 07-14-2020, 11:35 AM #3
Thank you, Tim! I will have a better look at the pan when the diff is out of the way. No visible leaks from what I can see now, thankfully.
I'll be using your video as a guide when maneuvering the diff out! Jacking the engine up a little with a piece of wood sounds like the way to go to avoid cussing.
Thanks for your videos!
Old 07-14-2020, 11:45 AM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by WeakSauz View Post
Hi guys,
Already new:
Anything else I may be missing? In other words, once I install this diff, I really dont want to have to wrestle it back in ever again haha
I will double that suggestion from @mtbtim . if you have access to the pan you should just re-seal the pan regardless. The seal pac starts to break down after about 18-20 years and will leak.
Old 07-14-2020, 01:12 PM #5
You guys typically use the orange FIPG on it?
Old 07-14-2020, 01:54 PM #6
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
Replace the needle bearing on the drivers side of the front diff if you're lifted.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 03:26 PM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
good stuff
Amazon.com: Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket - 3 oz. Tube: Automotive
this stuff is also top shelf IMO
Amazon.com: Hondabond High-Temp Silicone Liquid Gasket 1.9 fl oz: Automotive
Old 07-14-2020, 07:22 PM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The orange is for transmissions, transfer cases and differentials. The black FIPG @sleepydad linked for you is the correct stuff.
Old 07-14-2020, 07:24 PM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Good idea, and it just so happens @infamousRNR have a video for it.
Old 07-14-2020, 10:25 PM #10
Thanks guys! My front diff is a ECGS unit with the clamshell bushing installed already. (needle bearings eliminated)
I am so glad I made this thread now-- didn't even think about the oil pan! Might as well while i'm 90% there
Old 07-16-2020, 10:45 PM #11
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Was not aware this was a thing. Tim and Sean saving our asses again. Hate trying to gather all these little things needed/recommended for a lift
Old 08-04-2020, 07:35 PM #12
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
So I was under the impression the diff needed to be much more removed for the drop and went ahead and got stuff preemptively to do this re-sealing, only to find out the diff just needs to be lowered an inch or two for the spacers to slide in (and is a very easy job all around). That being said, does the diff need to come FULLY out to to drop the oil pan, or can it simply be lowered some and perhaps tilted out the way to allow clearance?
Old 08-04-2020, 07:42 PM #13
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The diff needs to come all the way out to drop the oil pan.
Old 08-04-2020, 08:49 PM #14
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Thanks Tim.
back , bolts , bushings , diff , front
Free 3rd gen front LCAs LV NV turbo8 Free 2 04-12-2019 01:27 PM
2001 4runner Front Diff and Rear axle/Diff assembly. Corpus Christi, TX zwalker16 For Sale: T4R Items 5 08-24-2018 09:53 AM
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
WTB: 5th gen front LCAs RedST4R For Sale: Suspension/Wheels/Tires 0 02-01-2017 04:19 PM
WTB: 4th Gen Stock Front LCAs frogers935 Want to Buy/Trade 0 09-18-2014 12:08 PM
