Old 08-04-2020, 05:11 PM #1
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Fuel Injector Wiring
When I was replacing my PCV Valve this past weekend, I noticed that the wiring on one of my injectors is exposed (See picture below). From what I can find, the wiring is part of the engine harness and the entire harness must be replaced to fix this. Is trying to repair the wiring an option, or is that just going to cause problems? At this point, I don't actually have a CEL or any pending codes to indicate there is any sort of problem. I've looked, and I can't find a part number for the harness, if anyone has the part number I'd appreciate that. I'd also appreciate it if anyone can provide any information on what years have an interchangeable harness with my 2000 limited so If I need to go hunting in a junkyard I know what my options are. Thanks.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 05:13 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I can't tell from the photo, is the wire exposed or is it the sheathing around the wire you're concerned with?
Old 08-04-2020, 05:34 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I had a similar issue on my 2005 V8 Tundra recently; the electrical connector to the injector wouldn't clip in all the way causing a misfire. I ordered a new injector connector from Amazon, came with a short lead of wires so it was already crimped and everything just needed soldered or crimped onto the wire harness, but I found out the old connector's oring broke inside the connector and prevented it from seating so I removed the oring and used the factory connector.
Long story short, check Amazon for injector connectors, seems pretty standardized across Toyota. That is, if your's can't be repaired.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 05:51 PM #4
There is wiring exposed, it's not just the outer protective layer that is missing.
Old 08-04-2020, 06:36 PM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
[/url]
I think I learned the trick from @TheDurk if you add 90980 before the part number printed on the connector you will find it in the parts search.
all of the connectors attached.
I know the connector for my 2000 but you will also need the wire parts.
you might want to consider something like this? they did all the hard work already and it's really what your after.
Toyota Fuel Injector Connector with wire pigtail - Kit-1079
find , harness , number , part , wiring
Fuel injector replacement, fuel rail stuck? pwxford765 3rd gen T4Rs 11 08-08-2017 10:51 PM
Bad fuel leak... Injector? Fuel Rail? Clone of the Mean Classic T4Rs 3 06-20-2014 11:50 PM
Desperately Need A Fuel Injector Wiring Harness For My 87 Runner robsn40 Classic T4Rs 4 05-08-2012 08:59 AM
PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure CBR_GUY_IA TSB 0 07-12-2009 09:44 PM
I finally found my problem... Fuel injector wiring question the_dingman Classic T4Rs 3 02-13-2008 05:38 PM
