Old 07-14-2020, 12:08 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Looking for a maintenance schedule
Has anyone put together a schedule for 3rd gen 4Rs? Maybe a spreadsheet of some sort. My 4RUNNER has 176k and is 23 years old. I really don’t want to go by what the stealership says.
Also, is it okay it get my oil changed every 5000 miles? When I got my truck back in October of 97 it was 3000. I’ve never had an oil issue, and my 4R burns very little oil.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 01:38 PM #2
Plenty of info available directly from Toyota on this (not the dealer):
https://www.toyota.com/t3Portal/docu...yota%20SMG.pdf
https://www.toyota.com/t3Portal/docu...49U_edited.pdf
5k mile oil change interval is 'severe service'
7.5k mile oil change interval is for 'normal service'
I do 5k oil changes without fear. With some used oil analysis to verify, you likely could go 10k miles with a good quality oil and filter with no ill effects. I use the shorter schedule to force me to give the truck a once-over more often.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-14-2020, 02:17 PM #3
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Based on preference I do my changes every 3k since where I live has severe stop and go traffic. But it’s just me
cashflow50 is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 08:20 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
*Engine Oil & Filter - Every 5k (And I use full synthetic)
*Auto Trans fluid drain and refill - Every 10k (You are basically exchanging out 1/3 of the system, approximately 4 - 4.5 quarts) Why wait 30k or whatever interval you choose for a full flush when you can just do more regular drain and refills? It's super easy. Remove the drain plug, replace it with a new crush washer and refill your system. Easy peasy and it will keep your fluid in great shape. I've confirmed this with a Blackstone analysis of my fluid.
*Manual Trans Gear Oil - Every 30k
*Transmission Magnetic In-line Filter (if you've installed one) - these are rated for 30k but I go ahead and also replace them every 10k when I do a drain and refill of the pan.
*Front Differential, Rear Differential and Transfer Case Gear Oils - Every 30k
*Engine Coolant - Every 30k
*Greasing of driveshaft zerk fittings - Every other oil change or every 10k
*Engine Air Filter - When it looks dirty. The more off-roading you do, especially in a convoy in dusty conditions, the more often you will want to replace it.
*Engine Spark Plugs - Depends on the type of plugs but the Iridium ones I believe are rated for 75k miles.
*MAF Cleaning - it depends on your driving conditions because it will get dirtier quicker if you off-road in dusty conditions. I'd say every 30k is probably plenty, but if you get a CEL code for a "Too Lean Fuel Ratio" that's a dead give-away your MAF is due for a good cleaning.
*Throttle Body Cleaning - Clean it during one of your services if it looks dirty. Every 50-100K would probably be sufficient.
*Timing Belt, Other Drive Belts, and Water Pump - Every 100k
*Other Associated Timing Belt Parts like the Idler Pulleys, Timing Belt Tensioner, Crankshaft Seals and Crankshaft Seal - Every other timing belt change or every 200k miles.
*Wheel Balancing and Rotation - Every 5k
*Brake Inspection - Every 30k
*Finally, like @phattyduck said, it's good to get under your rig on a more regular basis to look for problems you can address before they become a bigger problem that might happen at a very inconvenient time, like when you're on vacation with your family.
Good luck and Happy Wrenching!
Old 07-14-2020, 08:43 PM #5
Satter's Avatar
Satter's Avatar
This is great! Thanks so much. What is MAF Cleaning?
Old 07-15-2020, 01:53 AM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
MAF stands for Mass Air Flow. It's the sensor in your air intake tube that lets the ECU know how much air is coming in to make the proper adjustments to the fuel being delivered to create the proper air/fuel mixture your engine needs to run well. When the sensor wires get dirty, the sensor doesn't accurately record the amount of air coming in. More air is actually coming in than the MAF sensor is reporting to the ECU so the air/fuel mixture ends up being too lean and the Air/Fuel sensor or O2 sensor in the exhaust pipe reports this to the ECU creating a CEL (Check engine light) like P0171 System Too Lean (Bank 1).
Old 07-15-2020, 10:52 AM #7
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
There is also a maintenance schedule in every Chilton's Repair Manual. Just be sure you buy one that covers the year of your T4R. Best price is on Amazon.com
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 01:56 PM #8
DP182 DP182 is offline
DP182 is on a distinguished road
This is great!
I just recently got my first 4runner and also a 4x4 haha.
I definitely have some things to check out!
Thank you again!
DP182 is offline   Reply With QuoteReply With Quote
Old 07-15-2020, 04:47 PM #9
Satter's Avatar
Satter's Avatar
OMG. Every morning when I start my 4R I smell gasoline from the exhaust. However, the check engine light has never come on. The smell goes away after I’ve driven it for a while. I don’t think my MAF sensor has ever been cleaned or replaced. It may be running rich because the sensor is dirty?
Old 07-15-2020, 04:54 PM #10
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
ECU makes it run richer on cold start.
Old 07-15-2020, 05:30 PM #11
Satter's Avatar
Satter's Avatar
So that’s normal?
Old 07-15-2020, 05:43 PM #12
Satter's Avatar
Satter's Avatar
What’s the difference between Chilton’s and the OEM repair manual besides.....Jesus, look at the price! O.O
Old 07-15-2020, 05:45 PM #13
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
OEM will be more accurate and contain a lot more specs than the Chilton's manual.
Old 07-15-2020, 06:35 PM #14
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Find a Toyota FSM set for sale on Ebay. Don't waste your money on a Chilton's manual.
Old 07-15-2020, 09:24 PM #15
MagusWyatt's Avatar
MagusWyatt MagusWyatt is offline
MagusWyatt will become famous soon enough
MagusWyatt's Avatar
I was looking for the same thing recently and started putting together the information as I found it. Then I decided to get serious and apply my spreadsheet skills to create a worksheet that would automatically track everything for me.
From left to right, the columns are service title, service type, recommended time (in days) frequency of service, recommended mileage frequency of service, last known completed date, last known completed mileage, due date (in days) of next service, due mileage of next service, and notes.
The "Due" columns are color-coded by percentage of time or mileage until the next due date. They go through green (rest easy), yellow (start planning for it), orange (schedule it now), and then red (overdue).
The previous owner had quite a few maintenance records, so I've been exhaustively going through them and entering the information I have. You'll see that there is a lot of red on mine, that's where there were no records and it's something I plan on doing in the future.
I'm still working on it, but if there's an interest level I could send it out to interested parties once I'm done.
Looking for a maintenance schedule-screenshot-2020-07-15-jpg
1998 SR5
MagusWyatt is offline   Reply With QuoteReply With Quote
changed , miles , oil , schedule , truck
5th Gen T4R Maintenance Schedule Beerguy20144R 5th gen T4Rs 3 08-18-2020 11:52 PM
Maintenance Schedule? TOYOTA 09 General Discussions 3 05-25-2020 08:33 PM
Maintenance Schedule Sandpiper 5th gen T4Rs 7 01-07-2014 01:29 PM
maintenance schedule? triangles 3rd gen T4Rs 2 10-07-2010 12:46 PM
'04 Maintenance Schedule? wwilme 4th Gen T4Rs 1 03-16-2007 02:11 PM
