Originally Posted by Doc3g
The real question is do you really want the icons? If you don't want a digressive shock then the deal doesn't make sense. Just make sure that you read up on the icons and make sure it is the kit you would want if you were just buying a kit straight out.
That's a really good point. If not the Icons, I am planning on going with Bilstein 5100s all around. I'd probably lean more toward linear rather than digressive since I'm more a fan of bombing dirt roads, but I also use it as a DD in the fairly mild but snowy winters here. The Bilsteins are a digressive shock as well, but I just don't know how they compare to the Icons. Do you have any experience with either? Are the Icons more aggressively digressive than the Bilstein 5100s?
